Looking for Offenhauser Throttle Cable Pics
Old Aug 10, 2023 | 10:29 AM
2000duallydiesel's Avatar
2000duallydiesel
I'm looking for pictures or information on how the factory throttle cable is connected from people who are running the Offenhauser intakes on their 300six.
I'm going to be using a Holley 1850s carb and it's all going in a1981 F100. I would like to use the factory cable if possible. I don't mind going aftermarket but if I do, I want to order all the right stuff the first time.
Old Sep 14, 2023 | 11:33 AM
JCdad's Avatar
JCdad
FWIW, factory cable wouldn't work for me. Not sure about 1981, but my 79 was going to be short.
Used a universal throttle cable, add on universal bracket with QF450. Fender washer and lock nut on end of gas pedal linkage.
If you plan on using original cable, start with which Offy intake you are using. DP requires transverse carb mount, C runs front to back.
Old Sep 15, 2023 | 06:28 AM
2000duallydiesel
Problem Solved
I posted this over on my other thread. Should have posted it here too.
Originally Posted by 2000duallydiesel
Just posting this in case somebody searches it on the future. The carb is installed. There were four things I had to buy to use it with the factory accelerator cable.
1. 1 inch carb spacer
2. Summit Racing™ Billet Aluminum Throttle Cable Brackets SUM-210239BLK
https://www.summitracing.com/parts/sum-210239blk
3. Summit Racing™ Billet Aluminum Throttle Cable Bracket Adapters SUM-210242BLK
https://www.summitracing.com/parts/sum-210242blk
4. Edelbrock Throttle Ball Assortment - 12413
this assortment works with holley carburetors. Picked up at local parts store. https://www.summitracing.com/parts/edl-12413
Ford throttle attachment
Throttle attached
Showing slot on throttle bracket
Bolted in place
Side view
Side view
Top view
Old Sep 15, 2023 | 06:30 AM
2000duallydiesel
Good information. I think I would have run into the short cable issue if was using the DP. I have the C series.
2000duallydiesel
Sep 5, 2023 02:38 PM
Rembrant
Oct 14, 2021 02:03 PM
jvmcc
32
Jul 6, 2016 10:06 AM
Marty in PA
Apr 30, 2012 07:07 PM
liftedf100
Mar 29, 2006 07:28 PM
