Bent pushrod
Old Sep 10, 2023 | 10:43 PM
Awix316's Avatar
Awix316
3rd Gear
Bent pushrod
Hello everyone! I have a 300 that is skipping. I pulled plug wires one at a time and it's cylinder#2 that's dead. Plug fires, so I know it's good. I took valve cover off and I see the intake pushrod for#2 cylinder is out from under the rocker arm. I pulled it out and saw it was slightly bent so I got a new one and put it in.... Crank her over and it fired up, ran like ***t, and did the same thing to the new push rod..... Cylinder#4 also has a slightly bent intake push rod but it stays under the rocker arm...... Reckon I have a bad camshaft? Any info is appreciated....
Old Sep 11, 2023 | 05:32 AM
arse_sidewards's Avatar
arse_sidewards
You probably have a stuck valve. There's nothing that can really go wrong with the cam to result in too much lift to the point of binding and bending pushrods.
Old Sep 12, 2023 | 01:48 PM
pmuller's Avatar
pmuller
Is this problem with a stock camshaft?
What year engine?
Old Sep 14, 2023 | 12:09 AM
Awix316's Avatar
Awix316
3rd Gear
What year engine?
Yes, as far as I can tell everything is stock. The numbers on the block say it's a 1992 truck engine. There is no valve lash adjustment...... This engine is actually in an old Clark forklift. I'm assuming that someone put a remanufactured long block in it some time ago. It can't have seen much use; everything is so clean except for cylinder 2. It's obvious that it hasn't been firing for a minute because there's oily residue all in there and in the combustion chamber
the scratch across the valve was me pulling the head to me so I could lift it out
Old Sep 14, 2023 | 11:10 AM
JCdad's Avatar
JCdad
Stuck valves, likely valve guides shot - leaking oil into cylinder.
Old Sep 14, 2023 | 12:56 PM
pmuller's Avatar
pmuller
The cylinder head is earlier than 1985.
I'm assuming it has stud mount rocker arms?
Old Sep 15, 2023 | 03:26 PM
Awix316's Avatar
Awix316
3rd Gear
You don't have to adjust for valve lash... You just bolt them down.... The 2 rocker arms for each cylinder both sit in the same little metal "tray"....... Whatever style that is called
Old Sep 15, 2023 | 06:52 PM
pmuller's Avatar
pmuller
Then that would be either a 1985 or a 1986 head with pedestal mount rocker arms.
Can you push all of the valves a little ways down by hand?
Brentella
Dec 2, 2017 10:25 AM
huntke
Apr 9, 2012 02:10 PM
flyingasics
May 11, 2011 12:05 PM
Clint Knotts
Aug 10, 2006 04:50 PM
Rambomber
Jun 18, 2003 11:08 AM
