Throttle Cable
Old Mar 29, 2006 | 01:15 AM
liftedf100's Avatar
liftedf100
Throttle Cable
In Need To Know What Kind Of Throttle Cable That Is Easy To Install For Holley 390 Offy Setupim Planning On Ordering It From Jegs And I Wont To Get It All At Once And Do It Rightand If Anyone Can Post Pics Of Your Setup For Ideals On Brackets.thanks,and If There Is Anything Eles I Should Order Beside Carb,intake,and Cable Let Me Know.
Old Mar 29, 2006 | 09:53 AM
BigBear1's Avatar
BigBear1
I've got pics of a bracket I made in my gallery so that you can continue to use the Ford 1bbl. throttle cable on your Holley 390.
The bracket may not be easier (I have no experience with aftermarket throttle cables), But it is definetly cheaper. If you have a welder and some mechanical ability, which I assume you do if you are attemting to install a 4bbl. on an I-6, I say try and make the bracket. The bracket was much easier to make than I thought.
Old Mar 29, 2006 | 11:31 AM
liftedf100's Avatar
liftedf100
thanks for the help but ireally wnted to use a new cable my old one is a little thrashed i heard of okar cables being really good but what length cable do i need
Old Mar 29, 2006 | 04:26 PM
liftedf100's Avatar
liftedf100
heilp i need to know what cable to get i woult like to order everthing by 6 pm.
Old Mar 29, 2006 | 07:28 PM
5_labsownus's Avatar
5_labsownus
I used LoKar cable and bracket!
Gevans17
Aug 13, 2024 03:17 PM
NCook
Apr 20, 2017 11:32 PM
65 Econoline
Nov 20, 2016 09:00 AM
RageOfAntioch
May 1, 2016 05:23 PM
R1racer
Apr 2, 2015 08:15 AM
