Brake lights
Jan 26, 2023 | 03:44 PM
Brake lights
I have gone thru 3 of the pressure switch on the master cylinder. Does anyone have a better alternative than the oe style?
Jan 26, 2023 | 04:38 PM
Parts Nerd Extraordinaire
Are you using something other than DOT3? Have you try a different supplier? I've use the NAPA SL134 and DOT3 without issue.
NAPA SL134
STANDARD MOTOR PRODUCT SLS27
ALLSTAR 76251
Jan 26, 2023 | 08:58 PM
.... or, you could run it into a relay so that then the switch would only have to carry just enough current to trip the relay and the relay would switch the rest of the load.
Jan 27, 2023 | 02:57 PM
Are you by chance using silicone brake fluid?It loves eating up those pressure switches because most of them are not compatible.
Jan 29, 2023 | 05:14 AM
Mine did the same thing. A lot of them do that. I went and got this switch from Summit. Item #rfw-sw68. Don't know why I can't make a link work.
Jan 29, 2023 | 07:05 AM
I got a motorcycle style brake switch to replace the unreliable pressure switch, problem solved.
Jan 29, 2023 | 08:09 AM
Jan 29, 2023 | 08:53 AM
I used the same one as Effietrucker... went thru 3 pressure switches before I gave up...
Jan 29, 2023 | 04:21 PM
Harley-Davidson brake light switch # 72023-51D (made in the USA) This was 20+ years ago.
Jan 29, 2023 | 04:31 PM
Got a switch from auto zone about 4 years ago still working with silicon brake fluid.
Jonesy0027
Mar 27, 2022 08:42 PM
tvliftcabinet
Mar 6, 2017 11:16 AM
Pappys53
May 18, 2013 01:51 AM
Schmitty
15
Apr 1, 2010 01:29 AM
handx2
Sep 6, 2004 12:57 AM
