no brake lights, .help
Old Sep 5, 2004 | 10:24 PM
handx2's Avatar
handx2
i changed my master cylinder today,and now i have no brake lights.when i disconected the wires to the pressure switch,like the true genius tht i am,i tied to stick one of the wires on the throttle.it gave a small spark and blew a fuse.i`ve replaced the fuse,and now have tail ligts,but no brake lights.what else could it be?
Old Sep 5, 2004 | 11:23 PM
GLR's Avatar
GLR
Try hooking the two wires together ..if brake lights work it could be in the switch. I'd have to check my wiring diagrams, but, I think the brake lights also go through the T/S switch before going to light socet. This might then be a T/S switch problem.
Old Sep 6, 2004 | 12:57 AM
handx2's Avatar
handx2
thanks glr,
i hooked them together,and the lights came on.i cleaned inside the boots,and the posts,and that solved my problem.bad connection.thanks for the suggestion.i wanted to hook them together in the first place,but i was afraid it would short something out.
GuitarJesus
Jul 18, 2017 03:48 PM
Culvert
Nov 10, 2016 09:31 AM
r0cker
Jan 9, 2014 03:34 PM
dubbz
1983 - 2012 Ranger & B-Series
Mar 15, 2011 03:28 PM
beachrat
Electrical Systems/Wiring
Apr 30, 2008 07:16 PM
