Brake lights
Old May 17, 2013 | 06:08 PM
Pappys53's Avatar
Pappys53
Brake lights
My brake lights on my 53 quit working. Could it be the brake switch? It is a stock master cylinder under floor with stock switch.
Old May 17, 2013 | 06:14 PM
raytasch's Avatar
raytasch
Believe Nothing
The stock pressure switches are long known for failures. A more serious problem with these switches is when they deteriorate and take extreme pressure as in a panic stop to come on. You want the brake lights to come on when you make an easy stop. Replace the switch, less than $10.00 many places. Clean the wire contacts, too.
Old May 18, 2013 | 01:51 AM
1oldtimer's Avatar
1oldtimer
Crawl underneath, pull the wires off the switch and run a jumper wire between the two wires. If the lights come on then the switch is bad, if you still have no lights then the problem is elsewhere.
Lukes66
Feb 9, 2011 05:38 AM
rushlvr24
Dec 3, 2006 03:44 PM
halftoke
Electrical Systems/Wiring
Sep 5, 2005 09:55 PM
rkduff99
15
Dec 12, 2004 04:36 PM
handx2
Sep 6, 2004 12:57 AM
