No brake lights *** Fixed ***
Old Mar 17, 2022 | 07:49 PM
Jonesy0027's Avatar
Jonesy0027
Howdy Fellas,
I lost my brake lights on my ‘65. All other lights are working fine (headlights, rear running lights, turn signals, license plate lights, dome light). Fuses are ok.
Let me know your thoughts.
Fixed! See below.
Jonesy
Old Mar 17, 2022 | 07:57 PM
654x4's Avatar
654x4
Did you check for proper switch operation on the pressure switch? Mine was located on the outlet of the master cylinder.
Old Mar 17, 2022 | 08:25 PM
raytasch's Avatar
raytasch
Believe Nothing
The pressure type switch failure is very common.
Old Mar 17, 2022 | 09:33 PM
AZSCAWPION's Avatar
AZSCAWPION
The brake lights and signal lights share the same filament. If one works and not the other, it's not the bulb and the wiring should be fine. Likely the brake switch. If the original type that piggy backs on the MC, probably full of crud. You can jump the 2 wires to the switch to check. Remember, key on.
Old Mar 18, 2022 | 02:33 AM
Christmas's Avatar
Christmas
TSS more than likely if not the pressure switch. Test it first..
Old Mar 18, 2022 | 07:11 AM
Jonesy0027's Avatar
Jonesy0027
Appreciate the info. I’ll give it a try this weekend.
Old Mar 18, 2022 | 09:00 AM
raytasch's Avatar
raytasch
Believe Nothing
I have a bit more time so I'll weigh in again. Those pressure switches are notorious for going bad gradually. Some of the newer replacement switches require much more pressure to activate than necessary, acting just like an old switch displaying an early failure. YOU WANT THE SWITCH TO ACTIVATE THE LIGHTS WITH A SLIGHT PRESSURE ON THE BRAKE SUCH AS SLOWING DOWN, NOT AS IN A PANIC STOP.
Old Mar 18, 2022 | 09:55 AM
TA455HO's Avatar
TA455HO
Lead Gopher
If all else mentioned doesn't work try this. Its worked for me and worked for Chuck, too.
Light issue... - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Mar 18, 2022 | 02:30 PM
Red60's Avatar
Red60
If the rear turn signals work correctly it can’t be bulbs, rear wiring, or turn switch. Front wiring to the pressure switch, pressure switch, & light switch are still a possible contender for the rude component award. Most likely is pressure switch or those crummy connectors on said switch. I would test continuity on the switch with a helper pressing the brakes.
Old Mar 18, 2022 | 03:24 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I can be a grounding issue in the rear bulb housings or rear wiring at the connections. If you read my post I linked to - the fella was having the similar issue with rear turn signals working but not the brake light, but only on one side in his case. Here's one point I made which can cause the issue.
Since your running lights do work I'd think you've got a ground, but this check can eliminate a weak ground. Weird things can happen if things aren't grounded 100%. The lighter, finer bulb filament can be fine because it doesn't draw as much but the heavier filament can fail because not enough juice can flow to illuminate it, for example.
Old Mar 26, 2022 | 02:07 PM
Jonesy0027's Avatar
Jonesy0027
Howdy Fellas,
My ‘No brake light’ problem has been fixed by replacing the brake pressure switch. I appreciate everyone’s input.
I was afraid of kinking the brake line, but it all worked out. Pics below.
Jonesy
Old Mar 27, 2022 | 03:55 PM
FuzzFace2's Avatar
FuzzFace2
Good to hear you go it fixed.
I dont know what under the dash looks like to fit a newer plunger type stop switch?
AMC had a factory kit to change the PSI switch to the plunger type under the dash.
It was a switch and bracket the bolted to the pedal bracket. Pulled the wires through the firewall and hook them to the new switch.
Just something to think about the next time you are changing that switch out.
Dave ----
Old Mar 27, 2022 | 08:42 PM
Tom H So. Ca.'s Avatar
Tom H So. Ca.
Or you could use an older motorcycle mechanical brake switch. You would need to make a bracket and re route the brake wires.
Congrats!
Tom
Redstroker73
Jan 23, 2017 08:51 AM
walsh63
Jan 2, 2008 07:57 AM
jeepin
Electrical Systems/Wiring
13
Jul 1, 2003 11:17 PM
wolverineflight31
Sep 15, 2002 03:57 AM
Trail_Rider
Feb 4, 2001 08:40 PM
