Brake lights
Old Jan 26, 2023 | 03:44 PM
dans 51 f2's Avatar
dans 51 f2
Brake lights
I have gone thru 3 of the pressure switch on the master cylinder. Does anyone have a better alternative than the oe style?
Old Jan 26, 2023 | 04:38 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Are you using something other than DOT3? Have you try a different supplier? I've use the NAPA SL134 and DOT3 without issue.
NAPA SL134
STANDARD MOTOR PRODUCT SLS27
ALLSTAR 76251
Old Jan 26, 2023 | 08:58 PM
Old F1's Avatar
Old F1
.... or, you could run it into a relay so that then the switch would only have to carry just enough current to trip the relay and the relay would switch the rest of the load.
Old Jan 27, 2023 | 02:57 PM
leonharu's Avatar
leonharu
Are you by chance using silicone brake fluid?It loves eating up those pressure switches because most of them are not compatible.
Old Jan 29, 2023 | 05:14 AM
Marten's Avatar
Marten
Mine did the same thing. A lot of them do that. I went and got this switch from Summit. Item #rfw-sw68. Don't know why I can't make a link work.
Old Jan 29, 2023 | 07:05 AM
moejr's Avatar
moejr
I got a motorcycle style brake switch to replace the unreliable pressure switch, problem solved.
Old Jan 29, 2023 | 08:09 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Ron Francis Wiring SW68 Ron Francis Wiring Lever Brake Switches | Summit Racing
Old Jan 29, 2023 | 08:53 AM
jniolon's Avatar
jniolon
old and in the way
I used the same one as Effietrucker... went thru 3 pressure switches before I gave up...
Old Jan 29, 2023 | 04:21 PM
mtflat's Avatar
mtflat
Harley-Davidson brake light switch # 72023-51D (made in the USA) This was 20+ years ago.
Old Jan 29, 2023 | 04:31 PM
26tudor's Avatar
26tudor
Got a switch from auto zone about 4 years ago still working with silicon brake fluid.
Jonesy0027
Mar 27, 2022 08:42 PM
tvliftcabinet
Mar 6, 2017 11:16 AM
Pappys53
May 18, 2013 01:51 AM
Schmitty
15
Apr 1, 2010 01:29 AM
handx2
Sep 6, 2004 12:57 AM
