2011 6.7 HAS NO ELECTRICAL POWER
Old Jan 12, 2023 | 06:23 AM
OHBandit's Avatar
OHBandit
3rd Gear
I have a 2011 F350 6.7. Owned it for 7 years now. On the way to work this morning while driving everything went dead for about 2 seconds and truck just came back to life. Lucky I was 200 yards from pulling in the parking lot. Backed the truck in the parking spot and shut off and took the key out and opened the door. Closed the door, restarted the truck and all worked fine. Turned truck off again, opened door and put key back in ignition to restart third time and it's deader than a hammer. No power to anything other than the 12V cig lighter sockets. No power locks, windows, seats, dome lights no anything! Checked batteries and both show 12.8 volts. Now what?
Old Jan 12, 2023 | 07:01 AM
ToMang07's Avatar
ToMang07
Well, time to start chasing wires. Check the main power cables to the batteries. Grounds. Fuses. Then move to the BJB and start checking major harnesses. Sounds like a harness got damaged or loose to me.
Old Jan 12, 2023 | 07:52 AM
JoeUser's Avatar
JoeUser
How old are the batteries? Start there, with their condition (load tested). Also, check the cables and ends; any corrosion (between the battery posts and cables) or loose connections (such as the ground cable to body).
I've experienced the same thing with other vehicles in the past, when it turned out to be a bad ground (in one case a broken negative cable, inside the sleeve).
Old Jan 12, 2023 | 07:56 AM
OHBandit's Avatar
OHBandit
3rd Gear
Yep have to start chasing wires.
Old Jan 12, 2023 | 10:21 AM
lynnmor's Avatar
lynnmor
I believe that there were problems reported with a connector in the vicinity of the parking brake. Do some searching on here.
Old Jan 13, 2023 | 05:23 AM
senix's Avatar
senix
also check the wiring harness that goes underneath the engine and crosses over to the other side.
Old Jan 16, 2023 | 04:21 PM
OHBandit's Avatar
OHBandit
3rd Gear
Fixed!
Problem fixed. Removed kick plate on passenger side to get access to the fuse panel. Found a large red wire that feeds something just in front and under that fuse panel had a loose connection. Could see where it was oxidized and the connection was not tight. Cleaned it up and crimped the connectors back in and she is back to life.
Old Jan 16, 2023 | 05:44 PM
senix's Avatar
senix
A Self Repair is a good one. Thanks for reporting back.
Old Jan 17, 2023 | 07:57 AM
Overkill2's Avatar
Overkill2
x2 thanks for reporting back... Might have to be nosy and check mine out for schitts and grins... Good job.
phizkig
Apr 21, 2015 07:21 AM
kbarbee95
Dec 23, 2014 01:44 PM
MidwestKid34
Oct 28, 2012 06:37 PM
dan1101
15
Dec 18, 2009 05:57 PM
F0rdF0rever
May 17, 2004 07:29 PM
