At Wits End
Old May 10, 2022 | 01:34 PM
dans 51 f2's Avatar
dans 51 f2
At Wits End
Front turn signal problem. Both front turn signal flash together whether turn on left or right. Rear signals work just fine. Ordered replacement Grote t/s housing(has replaceable switch minus wire harness) on column and same results. Ran a new wire from switch on column to lt t/s with same results. Any ideas?
Old May 10, 2022 | 01:45 PM
casetruck1's Avatar
casetruck1
It sounds like it is loosing ground somewhere if both are flashing. Could start checking that by touching wire to light housing and ground to see if it changes anything.
Old May 10, 2022 | 02:34 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I second the bad ground statement. Verify there all wires are properly routed and not chafed or pinched with good ground connections.
Old May 11, 2022 | 08:55 AM
ron2565's Avatar
ron2565
I had same issue once and I did all kinds of things then I finally got around to check the ground and found two bad grounds.
Old May 11, 2022 | 04:12 PM
dans 51 f2's Avatar
dans 51 f2
Don’t they ground thru the mounting screws? If not, where is the ground wire?
Old May 11, 2022 | 04:20 PM
56panelford's Avatar
56panelford
They do but rust , paint can interfere . Take a wire from the negative terminal from the battery and contact it to the lamp housing to check..I had the same issue and poor ground was the problem..
Old May 11, 2022 | 04:50 PM
CharlieLed's Avatar
CharlieLed
Quite likely that the lights are miswired...parking lights are designed to illuminate on both sides simultaneously. If the wire for the parking lights is connected to the turn signals then there will be a problem.
Old May 11, 2022 | 05:36 PM
bobj49f2's Avatar
bobj49f2
His name indicates he has a '51 truck, if it's stock it would be positive ground.
Old May 11, 2022 | 06:37 PM
56panelford
Then I guess he'll have to use the positive post then...
Camoboy70
Electrical Systems/Wiring
Jan 3, 2022 02:11 PM
JSPhotographers
Sep 27, 2021 01:50 PM
Chuck208
Jan 8, 2018 03:03 PM
RDON
Mar 27, 2006 10:10 AM
sullivas
Dec 16, 2003 12:25 AM
