Wiper Motor issues
Old Jan 30, 2021 | 11:34 AM
maverick600's Avatar
maverick600
Wiper Motor issues
When I purchased my 79 F100, it had a on and off switch rigged up under the dash to turn on the wipers. I was finally able to try and figure out what was going on. The switch in question has 2 wires coming from it, one to a ground that is hooked up to where the ash tray is mounted and the other goes to the bottom of the motor casing. I am thinking the switch is actually for the ground and possibly the switch is bad and the wipers would be on all the time unless the ground is "broken" by this other switch? I am in the process of searching the forum now for clues. I have not found where the wiring from the wiper switch to the motor has been tampered with at all.
Old Jan 30, 2021 | 06:30 PM
72rtchallenger's Avatar
72rtchallenger
So if the rigged switch is left on to make the ground does the wiper switch work normally or do you have to turn off the rigged ground switch ?
Old Jan 30, 2021 | 06:45 PM
maverick600
Regular switch does nothing...only way to operate wipers is by the rigged switch.
Old Jan 30, 2021 | 07:36 PM
72rtchallenger
Old Jan 30, 2021 | 07:37 PM
72rtchallenger
Old Jan 31, 2021 | 10:15 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
All I got.
Old Jan 31, 2021 | 10:17 AM
77&79F250's Avatar
77&79F250
And some info from ND. I am sure one he sees this he will update it with locations.
Two differenttypes of windshield wipers, two differentwiper switches.
Two speed wiper switches have a low & high speed.
Intermittent (delay) wipers were optional on 1973/79 F100/350's and 1978/79 Bronco's. Intermittent is not another name for low speed!
DOOZ-17A553-A.. Two Speed Wiper Switch-Notused with intermittent wipers (Motorcraft SW-896) / Marked: D0OB-17A553-A orD/ Obsolete
1973/79 F100/350 / 1978/79 Bronco // 1970/71 Fairlane/Torino/Montego / 1970/72 Maverick/Comet.
SUSANVILLE FORD in Susanville CA = 530-257-2137.
NOS ONLY in San Jose CA = 800-667-6659.
WESLEY OBSOLETE PARTS in Liberty KY= 606-787-5293.
GREEN SALES CO. in Cincinnati OH = 800-543-4959.
D1OZ-17A553-A.. Two Speed Wiper Switch-Used withintermittent wipers (Motorcraft SW-1010) / Marked: D1OB-17A553-AA/ Obsolete
1973/79 F100/350 / 1978/79 Bronco // 1971 Fairlane/Torino/Montego.
NOS ONLY
BURNS FORD in Burns OR = 541-573-7278.
GREEN SALES CO.
And
D1OZ-17A553-A.. Two Speed Wiper Switch-Used with intermittent wipers (Motorcraft SW-1010) / Marked: D1OB-17A553-AA / Obsolete
DON'S TRUCK SALES in Fairbank IA= 319-365-2751.
MCDONALD OBSOLETE PARTS CO. in Rockport IN= 812-359-4965.
GREEN SALES CO. in Cincinnati OH= 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC = 800-476-9653.
There are TWO different intermittent wiper governors. 1973/77 is one type, 1978/79 is another.
D3TZ-17C476-A(replaced D1ZZ-17C476-A) Intermittent Wiper Governor / Obsolete
Old Jan 31, 2021 | 03:36 PM
maverick600
So I need to retract my last answer, when the rigged switch is on, and the original is off the wipers are in low. When I turn the original switch to high, the wipers go to high. When I turn the original switch to low, wipers follow but when I turn the original switch to off, the wipers continue to operate until rigged switch is off. I have not yet checked the switch for continuity yet.
Old Jan 31, 2021 | 05:59 PM
72rtchallenger
So with rigged switch off ,,with the orignal switch work in any position ?
Old Jan 31, 2021 | 06:03 PM
maverick600
No not at all.
Old Jan 31, 2021 | 06:17 PM
R&S20's Avatar
R&S20
If memory serves correct, it is not switch but in motor. The motor has a constant power feed with a set of contacts in motor that opens at a certain point. This is how the wipers always stop in down position. If the conatact point breaks wiper never stops.
Old Jan 31, 2021 | 06:50 PM
72rtchallenger
That may be correct if wipers cannot go to park they would continue to run
Marky48170
Aug 24, 2025 04:25 AM
1979camperspecial
Nov 30, 2013 01:31 PM
Tony_C
Jun 18, 2011 09:45 PM
GeeJay
19
Mar 13, 2011 07:37 AM
mwilson
21
Nov 19, 2002 12:41 PM
