TMI door panels
Old Nov 5, 2019 | 03:22 PM
jrockdiddy's Avatar
jrockdiddy
TMI door panels
Well,
looks like I forgot a step. I installed Altman easy latches but didn’t think about it when ordering Tmi door panels for a stock latch. (Don’t mind they chipped paint &#128579 any ideas?
Old Nov 5, 2019 | 04:41 PM
CharlieLed's Avatar
CharlieLed
Just notch the door panel.
Looks like you did a great job on welding/painting in the Altman mounting plate, what happened with the screws?
Old Nov 5, 2019 | 04:44 PM
jrockdiddy's Avatar
jrockdiddy
I don’t wanna notch the door panel and make it look terrible. On the screws, I guess I tightened them down too much. Chipping the paint. I’m gonna touch them up and see how they look
Old Nov 5, 2019 | 04:47 PM
CharlieLed's Avatar
CharlieLed
If you want the door to larch then the panel MUST be notched...if you are not able to do this without making if "look terrible" then take it to a shop.
Old Nov 5, 2019 | 04:56 PM
jrockdiddy's Avatar
jrockdiddy
I know the panel MUST be notched. This isn’t my first rodeo. My question is how would someone go about notching it and not screwing up the material ?
Old Nov 5, 2019 | 05:02 PM
CharlieLed's Avatar
CharlieLed
You sound like a man who knows his limitations...take it to a shop.
Old Nov 5, 2019 | 05:36 PM
EBEAR's Avatar
EBEAR
Take a walk around a wrecking yard there are vehicles that have a small plastic cover for the door latch area . You may be able to find a suitable cover . PS I know the mercedes I rebuilt for my daughter had them .
Old Nov 5, 2019 | 06:41 PM
Marten's Avatar
Marten
Instead of notching the panel would it look nicer if you cut a strip straight down the whole panel?
Old Nov 6, 2019 | 09:51 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Just thinking out loud,
Remove the panel and try to cut the notch from the back side, without cutting the fabric. Then peel the notched piece from behind the fabric. Then cut the fabric as needed to roll it around the cut edge, and glue it to the back of the panel.
If you are very careful, and take your time, you might be able to cut the panel with a cutting wheel on a Dremel tool. Go very slow and take small bites to keep from melting the plastic.
Like Charlie said; if in doubt, take it to a shop.
Old Nov 6, 2019 | 10:18 AM
Old F1's Avatar
Old F1
Just thinking out loud # 2, ... or maybe a hole saw (slow) from the back side ? (But I don't know crap ! )
Old Nov 6, 2019 | 10:28 AM
jrockdiddy's Avatar
jrockdiddy
thx Effie,
I agree on that workflow. I’m worried about snapping the plastic clips holding the panel on. I have a panel popper removal tool so I’ll be careful.
I’ll Report back later !!
Old Nov 14, 2019 | 09:13 AM
jrockdiddy's Avatar
jrockdiddy
Just an update, after I peeled back the fabric with a razor blade, and notched the panel with a dremel, there wasn’t much fabric to fold over and hide the cardboard. Had to use a little black spray paint on the cardboard. I think it turned out great
Old Nov 14, 2019 | 09:24 AM
EffieTrucker
I agree. Looks good!
Matt1966
16
Mar 1, 2022 08:56 PM
applebaggins
Oct 21, 2019 08:55 PM
Stangman70
Feb 12, 2019 06:07 AM
67highboy
Mar 17, 2016 02:56 PM
xc4jokestomper
1983 - 2012 Ranger & B-Series
Aug 4, 2011 02:31 AM
