Door Clip Pockets
Old Oct 20, 2019 | 04:21 PM
applebaggins's Avatar
applebaggins
Door Clip Pockets
I'm getting ready to attach the door panel on my 78 F250 following the advice of 77&79F250, but on the back of my door panel, the cups aren't all opened up the way as shown in the picture below. Do folks do some cutting / trimming before re-attaching the door panels with the push pins?
Old Oct 20, 2019 | 04:38 PM
440 sixpack's Avatar
440 sixpack
What kind of pins are you trying to use ? I've never had any problem with the correct ones.
Old Oct 21, 2019 | 04:51 AM
Ozzie H.'s Avatar
Ozzie H.
What cups do you speak of? A picture might help. Use the correct fasteners and be gentle with the old plastic. It gets a bit brittle with age.
Old Oct 21, 2019 | 05:47 AM
applebaggins
There are twisted wire pins (the original equipment) and there are plastic push pins as mentioned here ( https://www.ford-trucks.com/forums/1...l#post17392903 ). I'm trying to use the plastic push pins, but some of the recesses on the backside of the door - where the plastic pin would sit - are just a tiny hole instead of the open gap you see above.
Old Oct 21, 2019 | 06:56 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If you are using the original metal pieces with the foam/rubber and the 90* bend, you do not need to open the place they slip into. They slip into the gap behind the area I reinforced. If you want to use the "Christmas" tree like push pins, then time to Dremel notch the tab like in the thread you attached. I think in the last pic they were notched by the PO with a pair of dikes.
Old Oct 21, 2019 | 12:50 PM
tlrtucker's Avatar
tlrtucker
Mine aren't a C shape like yours. They have an elliptical shape where the head of the plastic push pin "screws" into. But my door panels are cheap LMC replacements.
Old Oct 21, 2019 | 08:55 PM
tndallas's Avatar
tndallas
Go buy the GM style plastic ones. Parts store can point you to them in the help aisle or stand. They're a bit longer than Ford. If you use the plastic ones and want to take the panels off you can mask the paint and use a hack saw blade to cut the plastic.
67highboy
Mar 17, 2016 02:56 PM
99expy
Apr 9, 2010 01:30 PM
Butter03
Apr 1, 2010 01:33 PM
sacky07
Feb 8, 2005 07:33 PM
faroffthetrack
Jul 3, 2004 06:07 PM
