Door Panel Clips?
Old Jan 27, 2018 | 10:41 AM
Matt1966's Avatar
Matt1966
Door Panel Clips?
Hi!
I am trying to repair and paint my awful Door Panels. Stripped the Panels from Trim and Armrest to fill up some old cracks and holes. What kind of Clips do you prefer for the Door Panels? Metal or plastic?
Old Jan 27, 2018 | 12:03 PM
tndallas's Avatar
tndallas
I used the GM style as they're a bit bigger and maybe not as rigid.
I heard someone say you could use a hacksaw to saw thru the plastic ones if you ever needed to remove your panel in the future. That would prevent breaking your panel.
Did you reinforce your door handle and other points with epoxy?
If you do a search you'll find some pics with some good places to reinforce.
Old Jan 27, 2018 | 12:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Pic: 383033-S is the plastic clip.
Old Jan 27, 2018 | 01:38 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I would NOT go back with the metal ones, great way to break the door panel mount tabs, if you do not have a door panel removal tool.
I like the GM ones because they are longer and have a bigger head surface area. And you can easily hack saw (just the hack saw blade with tape for a handle) thru them to remove the door panel to ensure you do not break the tabs.
Also behind the arm rest/finger cup area, there are 2 bolt heads that hold the metal bracket to the door. Notch the door panel (with a Dremel tool) so it will fit tighter to the door.
No worries the arm rest and finger cups cover the notches. Also upgrade to metal finger cups. And x2 on JY weld or 2 part epoxy reinforce the back side mount tabs.
Also make some thin sheet metal overlay/reinforcement pieces for the flat plastic tab that mounts to the metal bracket, under the finger cups. JB Weld it in place.
Old Jan 27, 2018 | 02:23 PM
Matt1966's Avatar
Matt1966
Thanks! I dont like the metal clips either. Dont understand if I have to move all
8 mountings on the backside of the Door Panel if I want to use the plastic clips?
Old Jan 27, 2018 | 02:35 PM
77&79F250's Avatar
77&79F250
NO you do not have to move them, all that grey stuff is just JB weld reinforcement.
Old Jan 27, 2018 | 02:53 PM
Matt1966's Avatar
Matt1966
Great! Will try to find the right kind of plastic Clips!
Thanks a lot!!!!!!
Old Dec 10, 2021 | 07:53 PM
tbear853's Avatar
tbear853
Just found this thread ...
Old Dec 10, 2021 | 11:14 PM
77&79F250's Avatar
77&79F250
Well it has been around since Jan 2018. Do you not check every thread for good info? Respond or not, I always read every new thread to learn as much as I can. And then sometimes I respond with some help.
Old Feb 27, 2022 | 09:52 PM
ivsamhain's Avatar
ivsamhain
To use the plastic clips I assume you have to cut slots in the mounting tabs? Mine have a through hole.
Old Feb 27, 2022 | 10:30 PM
tbear853's Avatar
tbear853
It appears not, but I am trying to get better.
Old Feb 28, 2022 | 07:58 AM
77&79F250's Avatar
77&79F250
Ever door panel I have seen always had a slot, be it cut or broke from PO's. Even with door panels in the JY they always have a slot. If yours do not, then you are either going to have to use the OEM metal clips. Or use a Dremel thin cutting clade and cut a slot.
I read every one, I do not reply to every one of them because I know to stay in my lane....sometimes. Lol Guess I need to spend more time in the garage working on my Ford trucks and not so much time on FTE.
Old Feb 28, 2022 | 09:53 PM
ivsamhain's Avatar
ivsamhain
Well here’s an original with the holes mostly intact. Otherwise not very good condition, driver side probably useable, passenger pretty well destroyed.
any thought on which primer/promoter to use with sem on the new manufactured panels?
Old Feb 28, 2022 | 11:53 PM
77&79F250's Avatar
77&79F250
With some time, effort and some Plastic epoxy (2 part plasti-weld) and or maybe some JB plasti-weld even the worse cracks can be repaired. And add in a metal finger cup reinforcement for good measures. And get some metal finger cups also.
I have remade this one to roll around both sides now.
JB weld it to the door panel.
Old Mar 1, 2022 | 08:30 AM
ivsamhain's Avatar
ivsamhain
Oh yeah I’ve checked out your wizardry pics. The pass side has about an inch holding it together at the arm rest line, and missing some pieces.
