2000 f350 V10 Misfiring/ shuddering accelerating on incline
2000 F350 v10 bucking/ shuddering at low rpm uphill
goes away when I punch on the gas pedal.
have only had the truck for a few days, tested coil packs and changed fuel/ air filter to no avail. No check engine light on, going to pressure test fuel system this weekend. I’ve read plugs are hard in this motor? Is there a way to test them? Don’t have a reader to see which cylinder is misfiring- if that’s even the case. They are motor craft (sp?) plugs in there now. Anyone had this issue and resolved? Anything else I can test before I start pulling sensors etc? Thanks!
How many miles on the plugs & boots?
It takes a lot misfires to set a code, but there is data that can be accessed to tell if a particular cylinder is misfiring.
A standard code reader can't access the data, but an OBDII port adapter and Forscan software can pinpoint a misfiring cylinder.
Long term misfiring can ruin a CAT.
Definitely check the fuel pressure.
If the plugs or boots have more the 50k on them I would change them (under $100) before digging into any sensors.
Yes, changing the plugs is tedious, but there are a lot info/tips/pointers in these forums.
Totally the plan. Going to test fuel system this weekend, luckily it’s not my daily driver. Unsure how old plugs are, just bought it 3 days ago with no history. If the fuel system checks out, will order plugs and boots and maybe a coil pack just in case. I’ll update as I complete things. Thanks for the reply!
Consider getting yourself a tube of dielectric grease too. Use it on coil pack to plug connections, and any other electrical connections you disconnect for repair. Keeps moisture out of connections, and eases disassemble for the next time you need to disassemble.
Also, use M/C plugs. Not sure about the 2000 model year, but having the Lisle plug removing tool handy could save some headaches.
His 2000 is a 2v which uses the old style one piece plugs, the Lisle plug tool is for the OEM two piece plugs used in the 3v motors, 2004+.
Sounds like a case of misfiring under load, I would guess degraded plugs or boots.
