Modular V10 (6.8l)
2000 V10 Missing When Lugging
Old Mar 20, 2011 | 03:57 PM
joeskeeter's Avatar
joeskeeter
My 00 V10 has a missing issue when the truck is lugging at low rpms. I have replaced all of the spark plugs, they were in fair shape. Have have no check light coming on. Anyone have an idea?
Thanks
Old Mar 20, 2011 | 05:33 PM
jh818's Avatar
jh818
Was this already happening prior to the spark plug change? What kind of plugs did you use? Boots changed also?
Old Mar 21, 2011 | 05:53 AM
joeskeeter's Avatar
joeskeeter
Plugs were replaced to try and fix the issue. I used the direct replacement motorcraft plugs. The missing is still there at higher rpm's I just notice it more when its at lower rpm's. Did not replace any of the boots they all looked fine.
Old Mar 21, 2011 | 07:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Either get the misfire counters read so you know which cylinder, or buy one new COP and play round-robin.
Sounds like you have a bad COP.
Old Mar 21, 2011 | 09:01 AM
joeskeeter's Avatar
joeskeeter
Talked to a local repair shop and they said they would hook it up to tell me which one is miss firing. Should you always replace the plug boots when replacing the plugs?
Old Mar 21, 2011 | 09:38 AM
jh818's Avatar
jh818
Absolutely. Highly recommended that you do.
Old Mar 21, 2011 | 09:43 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
my vote is a coil....
Old Mar 21, 2011 | 11:40 AM
joeskeeter's Avatar
joeskeeter
Took it to the shop they said #7 was bad. Off to the parts store to get one and change it out. At least its in the front and its not number 5. Any brand better than the other on these?
Old Mar 21, 2011 | 01:54 PM
jh818's Avatar
jh818
Stick with Motorcraft COPs.
Old Mar 22, 2011 | 05:04 PM
joeskeeter's Avatar
joeskeeter
Replaced the coil that the code said was bad and still have the miss. I had the codes reset. How much time or driving does it take for the codes to show up again?
Thanks
Old Mar 22, 2011 | 05:33 PM
jh818's Avatar
jh818
Try inspecting that plug as well to see if it may be defective or not gapped properly.
Old Mar 22, 2011 | 06:01 PM
joeskeeter's Avatar
joeskeeter
I inspected all of the plugs closely before I put them in and they all were the same gap.
Old Mar 22, 2011 | 06:31 PM
jh818's Avatar
jh818
Since the boots were not replaced, I wonder if maybe you may have some corrosion on the spring and it's not getting a good contact to the plug?
Old Mar 25, 2011 | 06:15 PM
Kennicol's Avatar
Kennicol
Hope you have better luck than I did.When my cop went out mine wouldn't reset. Kept showing missfire finally found out it took the computer out with out.A guy thats works on them said was a common problem and the computers are on national back order. So I sit and wait just hope if another cop goes bad it leaves the computer alone.
Old Mar 26, 2011 | 07:23 AM
JWA's Avatar
JWA
Thanks
Another thing to check is the individual harness connectors for the COP's. I had a similar miss on my 5.4 V8 showing up n Cyl #7 even though a known good COP and new plug were installed. Seems somewhere along the line the locking tabs on that connector broke and wasn't making good contact.
Start the engine and push in on each connector to see if that affects the idle. If so mark the offender and head off to NAPA picking up EC259 for about $19 each.
Definitely change the boots AND use dielectric grease inside them---just good practice!
