Spark Plugs
Old Aug 25, 2006 | 11:27 PM
BAJI26's Avatar
BAJI26
Question Spark Plugs
Can I put Bosh Platuim 4 Plugs in a 2000 Ex Limited V10?
What do you guys recommend?
Old Aug 25, 2006 | 11:34 PM
T18skyguy's Avatar
T18skyguy
I would stick with Autolite or NGK. Mechanics have reported on rare occasions the thin ceramic insulator on the Bosch plugs break off in the cylinder which is way bad.
Old Aug 26, 2006 | 12:06 AM
BAJI26's Avatar
BAJI26
Whoa so I guess I've just wasted $66. Put them in about a week ago and felt the difference in power, but after washing my engine it started to miss and I checked the plugs and found a few loose and then the engine ran fine. A day after it started again so Sat or Sun I will buy the $43 autolite and replace the bosh. Thanks!
Old Aug 26, 2006 | 01:22 AM
ptolalibertad's Avatar
ptolalibertad
just make sure you replace the plugs correctly..do a search and follow the correct procedures and you'll have less problems...also use motorcraft plugs
Old Aug 26, 2006 | 07:28 PM
wylecoyote's Avatar
wylecoyote
Mine skipped a little too after washing the engine. Once the water dries up it stops skipping. I just did my plugs too, I used the motocraft.
Old Aug 26, 2006 | 11:31 PM
RACERX7775's Avatar
RACERX7775
make sure you torque the plugs.
Old Aug 27, 2006 | 10:25 AM
ptolalibertad
All Of My Other Cars And Motorcycles I Have Washed The Engine With No Problems...light Wash..... But After Rading About The Problems Some Have Had I Do Not Wash My Exc V10 Engine..and Boy Is It Duuuuurrrty!!!!
Old Aug 28, 2006 | 02:31 PM
BAJI26's Avatar
BAJI26
I changed out the plugs from the Bosh Platium 4 to the Autolite double platium and all is well now.
