Axle question
Old Feb 27, 2019 | 06:57 AM
Tyler Truebenbach's Avatar
Tyler Truebenbach
Axle question
so i should have taken more than one picture, but i believe this is a dana 60. I dont know what its out of and the owner of the scrap yard its at doesnt know. There is a tag on it but its unreadable. Its ford dodge style with the diff on the passenger side, anyone have any information on this?
Old Feb 27, 2019 | 08:15 AM
matthewq4b's Avatar
matthewq4b
Looks like it is off a hyrail unit . So could be Dana 60 or 70. hard to tell with no pic of the diff.
Old Feb 27, 2019 | 08:23 AM
Ozzie H.'s Avatar
Ozzie H.
What is all that white stuff?
Old Feb 27, 2019 | 08:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
so i should have taken more than one picture, but i believe this is a dana 60. I don't know what its out of and the owner of the scrap yard its at doesn't know. There is a tag on it but its unreadable. Its ford dodge style with the diff on the passenger side, anyone have any information on this?
How many lugs do the wheels have?
Old Feb 27, 2019 | 08:44 AM
matthewq4b's Avatar
matthewq4b
There are 8 ND.
Old Feb 27, 2019 | 09:23 AM
NumberDummy
Originally Posted by matthewq4b
There are 8 ND
Pic is 1973/77 Dana 44 & 1973/75 Dana 60. Don't have a pic for 1976/79 Dana 60.
Old Feb 27, 2019 | 09:32 AM
matthewq4b's Avatar
matthewq4b
Not sure if you could tell ND but it is a Front axle.
Old Feb 27, 2019 | 09:49 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
but i believe this is a dana 60. Its ford dodge style with the diff on the passenger side, anyone have any information on this?
Unless I am just wrong as ever (been known to happen) Ford front axles Dana 60 or Dana 44 are dvrs side drop ...passenger side drop is a chebby thing. That axle looks to not have lock outs on it, so maybe it is a newer axle? Or a Dodge newer axle?
Here you want to learn about a Dana 60 BillaVista.com-Dana 60 Front Axle Bible Tech Article by BillaVista
Old Feb 27, 2019 | 10:01 AM
EQCMCAT's Avatar
EQCMCAT
I could be wrong, but I counted three different times and see ten (10) studs on the wheel, suspecting it to be off a F-550 or similar or heavier truck.
Old Feb 27, 2019 | 10:17 AM
NumberDummy
I couldn't tell...why I just changed the pic.
Old Feb 27, 2019 | 10:19 AM
matthewq4b's Avatar
matthewq4b
It has lock out hubs
it has a hub adapter to go from 8 to bolt to 10 bolt. These were used on Hy rail trucks to give them more off set to get the track width closer to the 4' 8 1/2" standard track gauge so the tires will ride on the rails. See below pic
The axle posted looks like it is off a hyrail truck
Old Feb 27, 2019 | 10:26 AM
matthewq4b's Avatar
matthewq4b
Here's a pic of the adapter it;s self.
Old Feb 27, 2019 | 10:46 AM
ford390gashog's Avatar
ford390gashog
Well that axle is very easy to identify it's a Dana 50 from a 99-2002 SRW F350 truck. The plastic ESOF hubs are the giveaway. The axle won't fit any older than a 99 because of the width and the bolt pattern is metric.
EQCMCAT's Avatar
EQCMCAT
That adapter explains the ten studs, thank for pointing that out. When you mentioned hyrail earlier it didn't dawn on me Rail Road use.
Old Feb 27, 2019 | 09:12 PM
78Broncoinpieces's Avatar
78Broncoinpieces
oops,, deleted redundant info.
Cheddar
Jun 9, 2019 06:55 AM
afonda
17
Jun 4, 2019 12:55 PM
Summonthis
Mar 25, 2018 09:26 PM
Thunderkiss65
May 1, 2016 02:47 PM
mudder460
Oct 21, 2009 02:19 AM
