Tilt Column with 4 way hazard
Old 11-15-2018, 05:48 PM
HyePo57's Avatar
HyePo57
HyePo57 is offline
Got the new tilt wheel a day ago... just now started looking at wiring (while I wait for my front steering/suspension parts to arrive). typical gm style plug with the usual suspect of colored wires... The Brown wire is for hazards and I'm pretty sure my '57 doesn't have a hazard switch.. so i hope someone who has done this already can chime in.
in my simply thinking, i'm figuring that the brown wire will go to a hazard flasher which will get powered by constant 12 volt... no other wiring needed since again i'm AGAIN assuming that the wiring is all done in the aftermarket column ... ????
somebody correct me before i burn the joint down... LOL
I am so prone to overthinking stuff
Old 11-16-2018, 04:53 PM
Byrd.Dog's Avatar
Byrd.Dog
Byrd.Dog is offline
Do you still have your factory wiring harness? If so, you would have to wire the flasher into the tail/marker circuit.
FordDuh
08-01-2016 04:39 PM
gslk1214
1999 to 2016 Super Duty
11-21-2011 11:27 AM
lorolr
07-26-2011 12:08 AM
bbussman40
04-13-2008 11:45 AM
jared66
18
02-20-2007 08:54 PM
Quick Reply: Tilt Column with 4 way hazard
