cp4 fuel pump
Old Jul 22, 2018 | 10:26 AM
imacowboy's Avatar
imacowboy
cp4 fuel pump
does this pump have a history of defectivenss
Old Jul 22, 2018 | 01:37 PM
Just Strokin's Avatar
Just Strokin
Yup. It hates water. Water is its worst enemy. Buy fuel from a high volume reputable source. Drain filter and change filter regularly.
Same goes for similar CP pumps on the other brands.
Old Jul 22, 2018 | 02:19 PM
KC8QVO's Avatar
KC8QVO
I have been monitoring some threads on the fuel pump replacement. I have thought about replacing mine. There is a video (below) that is a fairly complete walk-through of the removal of the old one and install of a new one.
I would be curious what options there are for "better quality" pumps. I quote that because that may be a loose term. As per the title of that video - that replacement was with a 2015 MY pump in place of the prior generation. I haven't found what the line of thought is there, whether it has a materials change or design change that makes it less susceptible to exploding with water intrusion, or even just low lubricity fuel, but it appears to be a direct replacement.
There appear to be some performance aftermarket upgrades as well to deliver higher pressure or volume.
I would imagine no high pressure pump is going to like water ingestion, emulsified or not. Though, is there a general consensus on fuel pumps that are more bullet proof than what Ford offers?
Old Jul 22, 2018 | 02:38 PM
KC8QVO's Avatar
KC8QVO
For documentations' sake here is another thread here I came across that has information relating to an aftermarket replacement along with a detailed description of the removal/install procedure.
https://www.ford-trucks.com/forums/1...-pump-diy.html
Old Jul 22, 2018 | 06:18 PM
cappa's Avatar
cappa
The 15+ pump is a stroker cp4. Puts out more fuel than the earlier version. Most guys will upgrade it with the 15+ turbo on the earlier 6.7's at the same time. Turbo is more reliable than the sst. Makes better, more reliable power especially when deleted and does better at high altitude. I have heard some claims that the 15+ cp4 has a better coating that should make it more reliable but I'm not positive on that. For the record thou, I follow allot of powerstroke forums and have not heard of many failures in the last 3 years or so since I bought my 15. Think it is blown out of proportion, just use good fuel.
fortheford
Oct 25, 2022 05:59 PM
99stroker_
Sep 19, 2017 01:00 PM
Webasto 9.1KW
13
Mar 5, 2013 02:44 AM
irishguyincc
1983 - 2012 Ranger & B-Series
Jun 5, 2006 01:28 PM
ddb
Sep 27, 2005 03:27 PM
