Fuel Pump Noisy After Replacement
Old Jun 5, 2006 | 02:33 AM
irishguyincc's Avatar
irishguyincc
I recently replaced the in-tank fuel pump assembly in my 87 Ranger. Since the repair, the high pressure fuel pump under the cab is now quite audible. It makes this kind of high pitch sound. It's pretty noticeable. I've checked fuel pressure, and that seems ok. Anyone know why one pump would get louder after the other was replaced? Also, the truck does seem a little sluggish. I have to really floor it now to get up to speed, and this wasn't always the case.
Old Jun 5, 2006 | 06:58 AM
tomw's Avatar
tomw
Two thoughts: 1) the in-tank is not providing enough fuel to keep the hi-pressure pump filled 2) something broke loose in the fuel line and is now flipping around inside the hi-pressure pump.
Did you use OEM or after-market replacement parts?
tom
Old Jun 5, 2006 | 01:28 PM
irishguyincc
The fuel pump assembly I installed was manufactured by Airtex. Is there any good way I can test the flow of the new low-pressure pump? Anything else I should try?
