Sponsored by: Real Truck
Relay Location
Old Jun 17, 2018 | 09:16 AM
MTP55's Avatar
MTP55
Relay Location
Are these relays the ones numbered 38-40some that are listed in the manual but not in the main power distribution box? I believe that two control ESOF. Also, is Ford the best place to get new relays? My horn and courtesy lamps never have worked then I found out those two relays are missing.
Old Jun 17, 2018 | 12:56 PM
Just Strokin's Avatar
Just Strokin
you can go to local parts house and get relays. Most of the relays are same or similar to the Bosch 30amp 5 pin relays even if only 4 pins are used.
Not all replay sockets will have relays. You need to check the relay location to see what it controls and determine is a relay is needed or not. You can swap one of the relays into the sockets to see if the lights and horn work. I suspect you are going to find one of the fuses inside the cab blown not a relay or fuse under the hood.
What year is your truck?
You can download the user manual here if you do not have one handy
Owners Manuals Search Results
Old Jun 17, 2018 | 01:14 PM
MTP55's Avatar
MTP55
I have the owners manual and the diagram doesn't show the last relays it lists by the power distribution box. It's a 2000 f250, 7.3. and the relays are completely missing where the manual says they are supposed to be.
Old Jun 17, 2018 | 06:59 PM
Just Strokin
Check fuses #12 and #14 in the cab.
The relay for the horn is inside the cab.
Old Jun 19, 2018 | 07:28 AM
Just Strokin
did you solve your problem?
djs556
Jul 31, 2020 05:54 PM
street131
Mar 14, 2011 04:25 PM
Sharpshooter77
Feb 18, 2009 10:31 AM
Welk49
28
Jan 18, 2009 09:14 PM
nrl_baseball
Electrical Systems/Wiring
Jun 14, 2003 11:11 PM
