quick relay?
Old Jan 18, 2009 | 01:59 PM
Welk49's Avatar
Welk49
quick relay?
does anyone know which relays are the A/C and Computer relays. Don't have a owners manual and wanted to switch them to see if I might have a bad relay. thanks
Old Jan 18, 2009 | 02:13 PM
BlueMule's Avatar
BlueMule
The top slot should be empty
Trailer marker lamps
Horn Relay
IDM power relay
PCM power relay
Old Jan 18, 2009 | 02:19 PM
BlueMule's Avatar
BlueMule
You can download a PDF version of the owners manual from here:
http://www.thedieselstop.com/faq/949...rs%20Guide.pdf
Old Jan 18, 2009 | 02:21 PM
Welk49's Avatar
Welk49
ok so where is the A/C relay I need to use? This truck not starting is making me sick.
Old Jan 18, 2009 | 02:34 PM
Welk49's Avatar
Welk49
thanks for the help Blue Mule
Old Jan 18, 2009 | 03:05 PM
WALJON's Avatar
WALJON
Are you getting fuel now?
Old Jan 18, 2009 | 03:33 PM
Welk49's Avatar
Welk49
i am getting fuel but still no fire, I can drain the fuel bowl and crank it over and the bowl fills back up. BUt I still cannot get any fire. All the relays are good. I am lost here
Old Jan 18, 2009 | 05:23 PM
WALJON's Avatar
WALJON
wait to start light coming on?
Old Jan 18, 2009 | 05:42 PM
Welk49's Avatar
Welk49
yes wait to start light coming on, stays on for 8 seconds maybe, then goes out
Old Jan 18, 2009 | 05:54 PM
WALJON's Avatar
WALJON
Wonder if you took your chip out if that would help?
Old Jan 18, 2009 | 06:00 PM
Welk49's Avatar
Welk49
I don't know, I was just talking with my wife, and I told her that it's probably something simple. I'll check that and see what happens.
Old Jan 18, 2009 | 06:14 PM
1dieselman's Avatar
1dieselman
Does the tack move when cranking it over? CPS maybe
Old Jan 18, 2009 | 06:28 PM
Welk49's Avatar
Welk49
yes, just put new CPS in, it moves. Took chip out and still same thing crank, but no fire.
Old Jan 18, 2009 | 06:32 PM
Tommy_Mills's Avatar
Tommy_Mills
check the connection that goes through your valve cover to your injectors, and glow plugs. they may be dirty or loose. Ive seen it a hundred times.
Old Jan 18, 2009 | 06:47 PM
Welk49's Avatar
Welk49
would one connector at an injector loose make it not fire at all though?
