Sponsored by: Real Truck
Another Forscan question on my '15 Superduty
Old Jun 16, 2018 | 12:19 PM
Fefanatic's Avatar
Fefanatic
I am experimenting on my '15 and did not find a spreadsheet for a '15 but I did find one for a '16 Here. I tried to change dpf % and it took but all I get is a blank screen. According to the spreadsheet the IPC 720-01-01 **** 9*** should enable it. I have a blank screen on the guages display. I get oil and trans temp on one screen, compass on the next, and then a blank screen on the third screen. I thought maybe it would need to be run to figure percentage and I drove it on a 10 mile highway run but that didn't change anything.
I also looked at enabling the global window open and it was already set to one. I checked the display and found that global window open is enabled in the display but I guess I do not know how to activate it as I tried to hold the unlock button down to activate and there was nothing. How do you activate remote window open?
The only success I had was to enable bambi mode where the fog lights are on with the high beam. I did have success there.
Edit to add: I figured out the global window open. Apparently that won't work if you are sitting in the truck and trying to use it. Only the front windows will lower but will not close. I can accept that as is.
Does anyone know if the '16 spreadsheet data is backwards compatible with a '15? If not does anyone know where a '15 spreadsheet is? I can find for F150 and others but not Superduty.
Any help appreciated.
Old Jun 16, 2018 | 01:46 PM
Just Strokin's Avatar
Just Strokin
The spreadsheet is for 2011-2016 trucks even thought it says 2016.
You also need to enable Forced Regen
IPC 720-01-01 **** 9*** F***
Old Jun 16, 2018 | 07:12 PM
Fefanatic's Avatar
Fefanatic
Worked like a champ. Thanks. Got everything I wanted done now.
Old Jun 19, 2018 | 10:08 AM
Towinrig's Avatar
Towinrig
I just finished installing the OEM fog light kit yesterday and would like to enable Bambi mode as well but couldn't because I didn't have an extended license. I have one now so tonight I am going to give it a try again. Any tips?
thebigtruck
Feb 20, 2022 01:09 PM
Flyct
Feb 20, 2022 11:05 AM
montauk1
Jun 13, 2016 06:42 PM
wannaBelkhuntin
May 8, 2012 09:25 AM
86F150302
Dec 23, 2007 08:09 PM
