I guess it is called "window track" but i need a new strip of it because it looks like the old one rotted and broke so now my when my windows down it rattles really bad. Anyone know where I can get some new stuff? Ive searched but I guess I dont know the real name of the stuff because I cant find any and when I think ive found it its like $100 +.
<a href="http://imageshack.us"><img src="http://img151.imageshack.us/img151/2862/window1ln5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
I might be confused on the exact part but I believe that National Parts Depot, or LMC Truck sell all the weather stripping and tracks and runners in the door pretty cheap.
I have seen it on ebay a little cheaper I have been looking for a set myself as both sides on my truck are gone and when there not rattling around the sound of air leaking by when you are driving will drive you nuts plus its winter now so you need to drive with the heat on full blast just to try to keep warm.
Still available from Ford...but...the Ford suggested retail price is: $44.37 PER SIDE
$75.00 for the complete kit looks pretty darn good now, doesn't it!
Division Bar = vertical window channel between the door glass & vent glass.
The weatherstrip fits into a groove in the division bar.
>>> The weatherstrips shown in the Bronco Graveyard link are aftermarket replacements, and are not the same as the weatherstrips that were factory installed.
Originally (as seen above) the division bar weatherstrip was a separate piece, not part of the weatherstrip that fits into the channel that runs up the rear of the door and over the top of the glass.
LMC:
*Door Glass Run: $20 ea.
*Door Anti-rattle kit: $80 Everything you need to do 2 doors.
^ This is the same as the one from the Bronco Graveyard you have the link for, but this is $5 more.
LMC:
I didn't realize though that it's retained down inside the door, and to do it right you should take the door apart and get it out of there. I was able to get enough of it though, and was able to take my crumbly piece out and glue this one here and there to keep it in place. It's molded in the top corners, and goes all the way down inside the door. It's sort of a u-shaped piece and has a very short fuzzy felt on the outside. I didn't have to get pieces 9 and 10 to stop the rattling, even though I did need them.
Yep I saw that in my catalog today. Ill order it ASAP. Thanks for the help everyone
