My 2017 F-350 Lariat has the global window open feature where if you hit the fob door open button twice and hold it down the second time, front windows open.
Is there a way to close the windows via the fob? It would be nice to be able to close windows via fob if it starts to rain.
My windows went down twice by hitting the button accidently. I live in an area where it rains almost daily so I stopped by the dealer and he went into the truck settings and deleted that feature.
Did you do all of the lines of code or only the checkbox line? All the lines need to be programmed for it to work
Ok maybe that's my mistake, I thought the check box would do the trick because was in IPC module, I'll try to do all lines when I get home
Thanks in advance
