03 F20 Odometer reads all 88888888
Old Feb 14, 2018 | 03:07 PM
raybones65's Avatar
raybones65
My odometer just started reading 88888888 and I cannot switch to the trip odometer
Please advise
Thanks
Ray
Old Feb 14, 2018 | 06:39 PM
bismic's Avatar
bismic
Do you have a King Ranch or a Lariat?
You can see if a gauge sweep can reset things.
With the key OFF, press & hold the Trip/Reset button. While holding the button(s) in, turn the key to the ON position (but do not start it yet). When the word "GAUGE" comes up, release the button(s) and start the engine. When the word "GAUGE" is displayed, the gauges will then swing to full scale then back. Release the button at that time. By pressing the Trip/Reset button, you can cycle through all the things that can be displayed.
If that doesn't work, you may need a new instrument cluster.
Old Feb 14, 2018 | 08:37 PM
raybones65's Avatar
raybones65
I have a Lariat
Old Feb 14, 2018 | 08:45 PM
raybones65's Avatar
raybones65
I tried that, but the word GAUGE did not show, it only showed test, and I held it for a minute or so
Thanks
Old Feb 14, 2018 | 10:28 PM
bismic's Avatar
bismic
That's why I asked about the Lariat! They show the word test. I have also read that you need to push Setup and Reset buttons at the same time to start the process (this works for mine, just wasn't sure about the 03's).
So did that help anything or not?
Old Feb 15, 2018 | 05:42 AM
Yahiko's Avatar
Yahiko
Not sure if FICMrepair is working on the clusters. >>> FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
I know that they do >>> https://circuitboardmedics.com
Both are very helpful and sponsor FTE
Old Feb 15, 2018 | 08:33 AM
raybones65's Avatar
raybones65
Bismic, it did not work, but you mentioned to push setup and reset buttons, where are those to press.
Yahiko, I replaced the FICM last summer
Old Feb 15, 2018 | 08:51 AM
Macrosill's Avatar
Macrosill
Sean was suggesting those companies to repair you instrument cluster, not replace the FICM.
Old Feb 15, 2018 | 10:54 AM
raybones65's Avatar
raybones65
Brian thanks for clarifying.
Bismic, I went through you process again this morning and cycled through and the odometer is back to reading the mileage.
Thanks for all your help
Old Feb 15, 2018 | 03:44 PM
bismic's Avatar
bismic
Glad you got it.
F-ReV
Jul 15, 2016 11:58 PM
redsplashman
2004 - 2008 F150
Dec 24, 2010 06:33 AM
padkin
Aerostar
Jul 4, 2008 04:20 AM
Beachbumcook
May 29, 2004 04:53 PM
