Unknown Wrench?
Old Feb 12, 2018 | 03:10 PM
Arizona97's Avatar
Arizona97
Unknown Wrench?
Can anyone identify the wrench in this pic?
unknown wrench?
Old Feb 12, 2018 | 05:18 PM
mattdoc88's Avatar
mattdoc88
Not me, but I'm curious: what's it used for?
Old Feb 12, 2018 | 05:32 PM
bismic's Avatar
bismic
DieselTechRon calls it a fan wrench that he uses when removing an 03 ICP sensor. I believe he used it because it was easily bent to fit a little better.
Old Feb 12, 2018 | 05:34 PM
Per4mance's Avatar
Per4mance
I know what that is. It's a tool made by KD for doing front end alinments.
Old Feb 12, 2018 | 05:35 PM
Pest007's Avatar
Pest007
Looks like a ratcheting wrench
Old Feb 12, 2018 | 05:39 PM
69cj's Avatar
69cj
Looks like it may be a serpentine belt tensioner ratchet.
Old Feb 12, 2018 | 05:54 PM
Arizona97's Avatar
Arizona97
Thanks guys, yes I grabbed that pic from DTRs video. Looks like a handy ratcheting wrench to have. I have google "Fan Wrench" and found nothing even close. Maybe someone will come up with it.
Thanks Ed
Old Feb 12, 2018 | 05:58 PM
Per4mance's Avatar
Per4mance
I'm telling you. It for tighten and loosing the upper control arms on the GM f and G bodies. There's special socket too
bismic's Avatar
bismic
I would bet this thing could be bent and work for ya
https://www.walmart.com/ip/Gearwrenc...tchet/49719904
Or, you can get one of these extra long ratcheting wrenches (they look like they could be slightly bent fairly easily) w/ a socket adapter (3/8" drive adapter fits in a 13mm ratcheting wrench and the 1/4" fits in a 10mm ratcheting wrench)
http://www.langtools.com/ratcheting-extra-long/
Amazon Amazon
Old Feb 12, 2018 | 06:19 PM
navistarnut's Avatar
navistarnut
I just took an el cheapo deep well socket and cut it down a little bit on the chop saw. That allows just enough room to attach the ratchet to get it loose.
Old Feb 12, 2018 | 07:43 PM
F350 1990's Avatar
F350 1990
Might be easier to make a permanent access plate (removable) on the floor pan/firewall.
Old Feb 12, 2018 | 10:32 PM
SmackDaddy's Avatar
SmackDaddy
Go at the ICP sensor from the top with the degas bottle, FICM and heat shield removed. Two 1/2” swivels a 6” and 10” extension are all you need.
Yama4fitty
Jan 7, 2017 06:43 PM
carterhooton
Garage & Workshop
Mar 6, 2015 08:28 AM
bigb56
Mar 25, 2014 08:56 PM
mudmaker
20
Jul 3, 2009 10:05 AM
eco
Garage & Workshop
Jun 18, 2007 02:37 PM
