Coolant level 2017 6.7
Old Dec 6, 2017 | 05:43 PM
Readgriff's Avatar
Readgriff
Where is everyones coolant level when cold?
Can you see the level in the driver side resivoir?
Thanks
Old Dec 6, 2017 | 07:43 PM
Just Strokin's Avatar
Just Strokin
Have you checked you owner's manual? Most times there is a photo of the coolant tank.
Old Dec 6, 2017 | 09:51 PM
cangim's Avatar
cangim
Mine is a 16, but when cold coolant is not visible
Old Dec 6, 2017 | 10:38 PM
Fireferg73's Avatar
Fireferg73
Should be at least to the Min level when cold.
Old Dec 7, 2017 | 07:01 AM
Readgriff's Avatar
Readgriff
Cangim
This is what my coolant level looks like below the min line.
I would think the level would be somewhere between min and max so you would no what level is in the coolant system.
What everyone else’s level look like?
Thanks
Old Dec 7, 2017 | 07:20 AM
djousma's Avatar
djousma
I tend to keep my coolant filled to the MAX line when the engine is cold, so that I can easily tell if I have lost any or not. During the winter months, when engine is cold it seems to drops below that a bit, in the summer when cold, it goes back to the MAX line. when engine is hot, its above the max line.
Old Dec 7, 2017 | 07:21 AM
cangim's Avatar
cangim
My last truck always sat about 1/2" below min when cold as well, this cold was around 40F if I recall, when fully at temp, it is above the max. Reading the manual, it should be between the two when cold. In summer when cold is 80 or 70F in the morning, it is between the two.
Old Dec 7, 2017 | 07:28 AM
dirthawg's Avatar
dirthawg
My 16 looks like this, however I suspect a leak somewhere. I've smelled a faint coolant smell the past couple of months and don't see any traces of coolant.
From the factory the reservoir was at MAX when hot and MIN when cold. It now is midway between the two when hot.
Old Dec 7, 2017 | 07:39 AM
cangim's Avatar
cangim
Just looked at another thread where I posted warm temp, it is just below Max
https://www.ford-trucks.com/forums/1...ntifreeze.html
niykinick
Aug 14, 2018 07:01 AM
aarmao
2009 - 2014 F150
20
Mar 13, 2013 08:48 AM
camodown
Jan 19, 2012 07:40 PM
kper05
6.7L Power Stroke Diesel
Dec 22, 2011 08:38 AM
Firefighter 1406
Feb 18, 2011 08:39 AM
