Coolant level 2017 6.7 - Ford Truck Enthusiasts Forums
Old 12-06-2017, 05:43 PM
Readgriff
Readgriff is offline
Readgriff is starting off with a positive reputation.
Where is everyones coolant level when cold?
Can you see the level in the driver side resivoir?
Thanks
Old 12-06-2017, 07:43 PM
Just Strokin
Just Strokin is offline
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
Have you checked you owner's manual? Most times there is a photo of the coolant tank.
Old 12-06-2017, 09:51 PM
cangim's Avatar
cangim
cangim is offline
cangim has a good reputation on FTE.cangim has a good reputation on FTE.cangim has a good reputation on FTE.
Mine is a 16, but when cold coolant is not visible
Old 12-06-2017, 10:38 PM
Fireferg73's Avatar
Fireferg73
Fireferg73 is online now
Fireferg73 is starting off with a positive reputation.
Should be at least to the Min level when cold.
Old 12-07-2017, 07:01 AM
Readgriff
Cangim
This is what my coolant level looks like below the min line.
I would think the level would be somewhere between min and max so you would no what level is in the coolant system.
What everyone else’s level look like?
Thanks
Old 12-07-2017, 07:20 AM
djousma
djousma is offline
djousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to behold
I tend to keep my coolant filled to the MAX line when the engine is cold, so that I can easily tell if I have lost any or not. During the winter months, when engine is cold it seems to drops below that a bit, in the summer when cold, it goes back to the MAX line. when engine is hot, its above the max line.
Old 12-07-2017, 07:21 AM
cangim's Avatar
cangim
cangim is offline
My last truck always sat about 1/2" below min when cold as well, this cold was around 40F if I recall, when fully at temp, it is above the max. Reading the manual, it should be between the two when cold. In summer when cold is 80 or 70F in the morning, it is between the two.
Old 12-07-2017, 07:28 AM
dirthawg's Avatar
dirthawg
dirthawg is offline
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
My 16 looks like this, however I suspect a leak somewhere. I've smelled a faint coolant smell the past couple of months and don't see any traces of coolant.
From the factory the reservoir was at MAX when hot and MIN when cold. It now is midway between the two when hot.
Old 12-07-2017, 07:39 AM
cangim's Avatar
cangim
cangim is offline
Just looked at another thread where I posted warm temp, it is just below Max
https://www.ford-trucks.com/forums/1...ntifreeze.html
joe sal
1999 to 2016 Super Duty
21
05-14-2018 11:53 AM
fordman19762003
01-03-2018 12:26 PM
Williams65
6.4L Power Stroke Diesel
12-27-2017 08:10 PM
Will_L
2017+ Super Duty
10-21-2017 07:10 PM
muneeb
04-20-2016 03:54 AM
Quick Reply: Coolant level 2017 6.7
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
