Fuel tank selector switch problem
Old Sep 17, 2017 | 08:54 PM
Ryanandlydia0604's Avatar
Ryanandlydia0604
Hi. So if I bypass the selector switch, everything works well. When I try to go through the switch and select front or rear tank, no fuel gets to the motor. I've tested the pump and it works fine. Individually, no problems. Any ideas? 1973 F-350 super camper special with a 390.
Old Sep 17, 2017 | 09:58 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Do you have a manual switch on the floor by the seat edge? Or a elec switch in the environmental control panel?
Yes yours is a 73 but..78/79 duel fuel tanks frame switch-Duralast/Universal 3 port fuel selector valve used with SW48 toggle switch Part Number: FSV4
Old Sep 17, 2017 | 10:14 PM
Ryanandlydia0604
The manual switch on the floor
Old Sep 18, 2017 | 12:44 PM
user 478546's Avatar
user 478546
Ryan, I have a 1974. I had to replace the valve in the floor next to the seat. I bought it from a local hydraulics supply store. Do you need a brand/model number? The one I got wasn't Ford, but it works perfect. I suspect your handle and shaft is broken from the ball in the valve. PM me if you want me to dig up the info. Of course I'm assuming you already know that the switch up on the dash just routes fuel level sensor to the gauge panel and doesn't "select" fuel supply routing...
Old Sep 19, 2017 | 02:10 PM
user 478546
Ryan, this is what you need. The center outlet goes to the fuel pump. Point the outlets toward you. The outlet to the left is for the MAIN. The outlet to the left is for the AUX. Reuse the hardware from the valve currently installed in your truck. It's a couple bolts, washers and nuts. I posted a link to your profile visitor page. You should turn on your private mail PM if you can.
Old Mar 19, 2019 | 11:58 AM
best0186's Avatar
best0186
Where did you get this replacement valve at? Thanks.
Old Mar 19, 2019 | 07:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The selector switch has nothing to do with fuel.
1973/74: The selector switch only changes the dash fuel gauge from one tank to the other.
1973/74 with dual fuel tanks have a manually operated fuel tank selector valve located on the floor adjacent to the drivers side of the seat.
1975/79 with dual fuel tanks have a fuel tank selector valve & solenoid assy mounted on the cross member.
The selector switch changes the tanks and the dash fuel gauge from one tank to the other.
Old Mar 20, 2019 | 05:53 AM
1978f-250's Avatar
1978f-250
He got it here: https://shop.broncograveyard.com/196...uctinfo/10260/
Old Mar 20, 2019 | 05:56 AM
1978f-250's Avatar
1978f-250
He very clearly stated in this 15 month old thread that he has the manual floor valve.
mikeceli
28
Aug 8, 2022 08:55 AM
newportman
19
Dec 27, 2011 10:45 PM
yomadmike
Jul 30, 2011 11:36 AM
AndysFords
Jun 6, 2007 11:50 AM
ptrill
Electrical Systems/Wiring
Oct 8, 2002 08:07 PM
