1974 F250 Ranger fuel tank selector valve, fuel gauge selector switch. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Reload this Page >
Old 12-17-2016, 01:42 PM
mikeceli
mikeceli is offline
mikeceli is starting off with a positive reputation.
My 1974 F250 has the front and rear fuel tanks that appear factory. It has the "Main Aux" switch on the climate control panel, with 3 wires orange, green w/ orange tracer, green w/ red tracer.
It also has a manual fuel tank selector valve, under the floor pan, below the drivers outboard seat belt. The mounting holes and handle pass thru hole, in the cab, look factory stamped. The is NO wiring in the cab, or under it, for a electric tank selector switch.
Did Ford build these like this? It sure looks like it. I guess one had to select the tank and select the gauge? Seems odd.
Thanks.
Old 12-17-2016, 01:56 PM
march's Avatar
march
march is offline
march is gaining momentum as a positive member of FTE.march is gaining momentum as a positive member of FTE.
My 73 was the same way. Manual valve with dash switch. The dash switch just changes the fuel level gage between tanks.
Old 12-17-2016, 05:14 PM
mikeceli
mikeceli is offline
Very interesting that ford would set it up that way. Oh well,is was a long time ago. Thanks.
Old 12-17-2016, 05:16 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Yes, that was factory. In 1973 and 74 the dual tanks had a manual selector valve to switch the fuel tanks and had the switch mounted in the HVAC panel to switch the gauge.
In '75 the system was changed so it was all electric and the switch on the HVAC panel did both functions, switching the gauge and tank.
Old 12-17-2016, 05:17 PM
redcreekauto
redcreekauto is offline
redcreekauto is starting off with a positive reputation.
Yes my 74 has the same setup. Manual valve to switch tanks and electric switch to show the level in tanks.
Old 01-31-2017, 02:31 PM
mikeceli
mikeceli is offline
Belated THANK YOU, for the replies!
Old 09-21-2018, 06:57 PM
JimJams
JimJams is offline
JimJams is starting off with a positive reputation.
does anyone happen to know if there is a conversion to the 1975 electric switch? i have a 1973 f250 with a 460ci with the manual switch.
Old 09-21-2018, 07:37 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Pic: 9189 valve shown at center lower, 9A050 switch shown at upper right.
Old 09-21-2018, 11:41 PM
JimJams
JimJams is offline
ty for the info but i'm still wondering if it possible to install the 1975 electric switch into a manual switch 1973?
that is if in 1975 they went to the electric switch over the manual?
Old 09-22-2018, 12:12 AM
1TonBasecamp
1TonBasecamp is offline
1TonBasecamp is gaining momentum as a positive member of FTE.
Can you see on the back of the switch whether it's got two rows of terminals?
For the lowly utility Broncos, they got the manual selector valve all the way through the '77 model year. The dash switch only handled the gauge functions, just like yours is. The switch itself had two full rows of terminals so you could use the one row for gauge duties and the second row to control an electric valve.
It's possible of course that your switch is not like that, as the position of the Bronco's switch allowed for the large body, while the one in the heater controls might have been a slimmer version. However, it would be worth a look if you don't know already. Sounds from the description of the wire colors that you've already had the switch out and could confirm it's configuration.
Paul
Old 09-22-2018, 01:04 PM
NumberDummy
Your switch is not the same!
D3TZ-9A050-A .. Selector Switch - 3 terminals - Use with dual fuel tanks / Marked: D3TB-9A050-AA / Obsolete
1973/74 F100/350 - Use with manually operated fuel tank selector valve.
This switch only changes the dash fuel gauge from one tank to the other.
D3TZ-9A050-B .. Selector Switch - Use with dual fuel tanks / Marked: D3TB-9A050-BA / Obsolete
1973/77 Bronco // 1975/85 Econoline.
D5TZ-9A050-A .. Fuel Tank Selector Switch - 5 terminals / Marked: D5TB-9A050-AA / Obsolete
Use with dual fuel tanks and D5TZ-9189-B Fuel Tank Selector Valve & Solenoid Assy. / Obsolete
1975/79 F100/350 // 1980/86 F100/350 except with dual fuel line system, except 460 & 6.9L diesel.
This switch changes the tanks and the dash fuel gauge from one tank to the other.
Old 09-22-2018, 05:34 PM
JimJams
JimJams is offline
Thanks that made everything clear
Old 09-22-2018, 06:32 PM
banoness
banoness is offline
banoness is starting off with a positive reputation.
Hi all, I was actually also going to post on this topic tonight as well really looking to parts dummy for help. I have an old style valve which appears to be part number D5TB-9F271-AA. I want to use this valve vice the newer style that is made of plastic and seems pretty cheap. I can't find one anywhere, any thoughts? I don't want to use this one if I can't get a replacement in case it ever breaks.
This valve came off a 1975 supercab. Please see pics.
Old 09-23-2018, 01:04 PM
NumberDummy
I have an old style valve which appears to be ID engineering number D5TB-9F271-AA
D5TZ-9189-B (replaced D5TZ-9189-A & D8TZ-9189-A) .. Fuel Tank Selector Valve & Solenoid Assy / Marked: D5TB-9F271-AA or D8TB-9F271-AA or D9TB-9F271-AA) / Obsolete
1975/79 F100/350 ~ No Ford dealer or obsolete parts vendor has any.
This valve was used on 1975/79 F100/350's. The switch (D5TZ-9A050-A - see post #9) used with this valve, changes the tanks and the dash fuel gauge from one tank to the other.
waltharper
11-23-2017 06:21 PM
Fordboy880
06-19-2017 04:11 PM
Fummins
25
12-28-2016 09:24 AM
rterril02
11-20-2016 01:12 PM
newrevnorton
10-30-2016 01:25 PM
Quick Reply: 1974 F250 Ranger fuel tank selector valve, fuel gauge selector switch.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
