1979 fuel tank switch
Old Oct 2, 2002 | 08:03 PM
ptrill's Avatar
ptrill
Post 1979 fuel tank switch
my truck will not switch to the rear tank, i believe my switch is shorting out, what are the different wires for so i can check and see if it will change
Old Oct 2, 2002 | 08:38 PM
kioolt's Avatar
kioolt
I'm not sure, but I think for that year truck all you need to do to check if your switch is bad is to find the fuel selector valve and check for voltage being on when the switch is set for one of your tanks and voltage being off when the switch is set for the other tank.
Old Oct 8, 2002 | 03:04 PM
Dogdecur's Avatar
Dogdecur
Ptrill,
What happens exactly when you make the switch? Does the fuel gauge change....does it still pull from the front tank. The Haynes guide has a good section to test the switch/valve by disconnecting the fuel lines, having someone flip the switch to see if the valve changes.
I thought I had a bad switchand/or valve, but it turned out I had a hard-to-see crack in a section of the rubber fuel line causing me to pull air instead of fuel. The check I made on the showed the switch and valve worked well.
Let us know.
Steve
Old Oct 8, 2002 | 08:07 PM
topo4u2's Avatar
topo4u2
