Sp or Lv trans fluid
From what I understand I should be using Lv transmission fluid in my truck. 2008 f250 V10, torqueshift trans. The parts store says Sp. Which is it? Thanks Bill
there were some owners manuals conflicts about this.....SP, then when SP was nearing end of supply LV, then when it appeared that SP would be available SP again......confusing indeed
my personal take , and take it for what its worth, the switch to LV was to squeeze some more MPG out of the truck to make the stats look good...I dont think long term reliability was a primary consideration. LV is thinner than SP.
so basically, if you care more about MPG and do not do heavy towing...you could probally get away with LV.
If long term reliability are more important then MPG and you tow....id go with SP.
my opinion of course.
granny_rocket
May 10, 2015 04:49 PM
timellis
Mar 24, 2012 07:39 AM
