Sponsored by: Real Truck
Sp or Lv trans fluid
Old Aug 14, 2017 | 01:49 PM
2stepn's Avatar
2stepn
From what I understand I should be using Lv transmission fluid in my truck. 2008 f250 V10, torqueshift trans. The parts store says Sp. Which is it? Thanks Bill
Old Aug 14, 2017 | 03:54 PM
speakerfritz's Avatar
speakerfritz
there were some owners manuals conflicts about this.....SP, then when SP was nearing end of supply LV, then when it appeared that SP would be available SP again......confusing indeed
my personal take , and take it for what its worth, the switch to LV was to squeeze some more MPG out of the truck to make the stats look good...I dont think long term reliability was a primary consideration. LV is thinner than SP.
so basically, if you care more about MPG and do not do heavy towing...you could probally get away with LV.
If long term reliability are more important then MPG and you tow....id go with SP.
my opinion of course.
Old Aug 14, 2017 | 04:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Either SP or LV is fine.
mtboys84
2009 - 2014 F150
23
May 11, 2018 11:13 AM
granny_rocket
May 10, 2015 04:49 PM
BiggDogg77
Jan 30, 2013 07:01 AM
timellis
Mar 24, 2012 07:39 AM
Jc_4_07
Jul 7, 2009 01:40 AM
