Sponsored by: Real Truck
Transmission filter
Old Aug 13, 2017 | 04:53 PM
DJRAAL's Avatar
DJRAAL
Transmission filter
I have a F 250 6.0L diesel with a 5 speed transmission the mitsubishi I have the exterior filter that I change regularly.
Is there also a internal filter? When should it be changed if it has one.
The maintenance schedule does not mention it to change.
The truck has 93,000 miles on it?
Old Aug 13, 2017 | 08:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What do you mean by, "5 speed transmission the mitsubishi?"
The Ford 5 speed with an external filter does not need the internal filter changed.
Old Aug 14, 2017 | 09:25 AM
DJRAAL's Avatar
DJRAAL
It shows two filters FT 144 & FT 145 internal and external. Watched a video on youtube the shows the changing of both but it doesn't say at what milage the internal should be changed.
Old Aug 14, 2017 | 10:36 AM
Bently_Coop's Avatar
Bently_Coop
Assuming you have the 5R110 Automatic, I would recommend upgrading to the 2008+ filter and pan. See link below for more information.
https://www.ford-trucks.com/forums/1358699-removed-stock-6-0-transmission-pan-installed-2008-6-4-trans-pan-and-ft-180-filter.html
Old Aug 14, 2017 | 01:15 PM
DJRAAL's Avatar
DJRAAL
https://www.ford-trucks.com/forums/1...80-filter.html
How can I Identify which one I have. The paperwork just says 5 speed transmission? I have the automatic transmission. But don't know if it's the 5R110
Old Aug 14, 2017 | 01:23 PM
Mark Kovalsky
The internal filter should be changed when the transmission is rebuilt. It doesn't need to be replaced before that. That changes if you install the 2008+ pan and filter. That one does need to be changed at regular intervals.
It's the 5R110. That was the only automatic available.
Old Aug 14, 2017 | 01:28 PM
DJRAAL's Avatar
DJRAAL
Thanks for the info.
What is the reason to change to the 2008 pan and filter?
Old Aug 14, 2017 | 02:58 PM
Misky6.0's Avatar
Misky6.0
It is a slightly deeper pan, which allows you to upgrade to the BETTER internal filter which filters 100% of the trans fluid. This was done in 2008, since Ford deemed it worth a re-design it says a LOT about it's effectiveness vs. the "toilet-paper like" external filter which ONLY filters 10% of the fluid - once the trans is up to temp.
Old Aug 14, 2017 | 03:54 PM
Bently_Coop
Excellent information, couldn't have put it better myself.
Old Aug 14, 2017 | 04:09 PM
DJRAAL's Avatar
DJRAAL
Thanks I appreciate the info.
Sounds like a very good reason to do that.
Do you know how much more fluid it will take and can I eliminate (keep the housing but no filter in it) the external filter?
Old Aug 14, 2017 | 04:33 PM
Mark Kovalsky
It isn't much more fluid. You can eliminate the the external filter.
Old Aug 14, 2017 | 04:40 PM
DJRAAL's Avatar
DJRAAL
Thanks everyone for the help I appreciate it.
Leon82
Dec 27, 2013 10:07 PM
vancouver f250
Aug 16, 2013 10:45 AM
whporwil
6.4L Power Stroke Diesel
Dec 23, 2011 02:25 AM
