Looking for recommendations for 2 bbl carb
Old May 15, 2017 | 11:15 PM
One79one71's Avatar
One79one71
I am thinking the 1bbl I have on my 79 is way overtaxed especially now that I have a highway transmission. I think its dieing after having sat anyway.
I am considering something like a motorcraft 2100/2150 or a 400 cfm Holley and an adapter to match it up to my stock intake. I do not know much about stuff like this but I assume I can mount most any carb with a 2bbl holley adapter?
I would also consider an intake swap.
43-4502WH
what are my options? Much obliged!
Old May 16, 2017 | 07:10 AM
The Frenchtown Flyer's Avatar
I would use a 2V carb on an aftermarket intake with the appropriate carb adapter. Either a MC 2100/2150 or a Rochester 2GC. Both are inexpensive options.
Old May 16, 2017 | 07:31 AM
One79one71's Avatar
One79one71
Thanks for the reply. Good to see u chime in FF... been a while, I havent been active here...
Something like this? are all mc 2150 the same?
carb carby carburetor fit MotorCraft 2150 Jeep/AMC/Eagle/Pacer 258/4.2 carby | eBay
Old May 16, 2017 | 08:58 AM
TheDudeAbides's Avatar
TheDudeAbides
I run an mc2150 that I pulled from an 80s f250 with a 351w under the hood. they're simple carbs, easy to rebuild, and even easier to tune (in my experience.) FF is right though...to reap the full benefits of the extra air/fuel, one should consider a different intake manifold. choking a 2 bbl down to a single barrel orifice kinda defeats the purpose. I suppose it would be possible to hog out, then smooth the bore once you bolt on your adapter to open it up? I've heard some fellas get some "gains" from that.
Old May 16, 2017 | 09:54 AM
One79one71's Avatar
One79one71
Good point Abides.
Old May 16, 2017 | 11:09 AM
HoustonDave's Avatar
HoustonDave
not a carb expert but when you refer to a 'highway transmission' I assume you mean something with a decent overdrive? IF that is the case your air requirements at highway speeds are LOWER, not higher, since the engine is turning fewer rpms. Better performance, carb needing rebuild, etc. are good reasons for needing a new carb - but not the transmission.
Old May 16, 2017 | 03:15 PM
One79one71's Avatar
One79one71
LOL HD- in theory you are right. but in practice I need more fuel to propel me to 90 mph!
Old May 16, 2017 | 03:27 PM
TheDudeAbides
yeah but that requires the additional fuel/air to be burned more efficiently for the condtions. then you get into cams, exhaust mods, ignition upgrades, p/p the head, etc. gotta pay to play.
Old May 16, 2017 | 08:06 PM
One79one71's Avatar
One79one71
I will look into replacing the intake and at least blocking off the egr pipe. I also need to take that useless cat out of the exhaust.
chops1987
Mar 14, 2007 08:10 PM
lilman320
May 13, 2006 11:35 AM
podman152
Jul 15, 2004 12:02 AM
pcmenten
Jul 10, 2002 11:19 AM
