Fuel pump: Mechanical vs Electric (underbed tank)
Old 02-07-2017, 06:02 PM
WallaceSF's Avatar
WallaceSF
WallaceSF is offline
Hi Folks:
I was wondering for those of you that moved your tanks back, was the stock fuel pump able to pull fuel reliably? Assuming your lines were primed (dry seems asking a lot), could it keep it? For the folks that went electric, any does/don't I should be aware of?
Thanks,
John
Old 02-07-2017, 06:41 PM
schoo's Avatar
schoo
schoo is offline
If elect I would put inertia switch at the top of the list
Old 02-07-2017, 06:43 PM
pholmes350's Avatar
pholmes350
pholmes350 is offline
I'm looking for the same lessons learned John. I'm going to use an electric pump when I get to that end of the truck but always looking for tips to improve. I don't mean to hijack your thread but along those lines I would also be curious of a recommended fuel pressure and flow rate for a 215 six cylinder.
Old 02-07-2017, 08:30 PM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
carb I would run a mechanical pump, tried and true reliable. Fuel injection I use an in tank pump. Again tried and true reliable OEM designs.
Old 02-07-2017, 10:31 PM
tip49's Avatar
tip49
tip49 is offline
EFI electric fuel pump
I have electric pump mounted on frame rail behind cab; will be changing to intank at some point due to noise of pump, either from cavitation or heating. Also have inertia switch in line with pump.
Old 02-08-2017, 11:41 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
With the tank all the way in the back, and today's gas, I'd go electric, mounted back near the tank. Many threads in the past on these.
For stock 48-52 engines, a good pump is the Airtex E8016S (12v), they make a 6v model too. This is a low pressure pump, tops out at 4 psi, you may want a regulator to go with it. The Holley 12-804 is a really good unit.
Old 02-09-2017, 05:53 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
I've had no problem with the stock pump but I did install a new one.
Old 02-09-2017, 06:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Not to put too fine a point on it, but have you driven yours in hot weather yet, for extended periods? Flat V8's are the worst with their pumps up on top of the engine, but any fuel system that has 10+ ft of line exposed to road and exhaust heat on the suction side is going to struggle to get gas.
Old 02-10-2017, 05:23 AM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
My truck will probably never get your kind of heat here in Michigan Ross. But certainly a good thought if I drive down there on a road trip
smoke n tires
10-15-2011 10:26 PM
big hoss 29
11-22-2007 09:08 AM
68shortbedmo
04-25-2007 07:56 AM
SamD
1947 and Older Ford Trucks
03-21-2004 01:18 PM
Farfaraway
08-04-2002 11:43 PM
Quick Reply: Fuel pump: Mechanical vs Electric (underbed tank)
