01 7.3 scanner not communicating w pcm
Old Jul 17, 2015 | 05:02 PM
small_farms's Avatar
small_farms
Ok I've got an 01 7.3 and the scanner I'm using won't connect to the pcm. I had it remanned and put it back on still nothing. Took the idm out and swapped it for a buddies. Still nothing. All fuses are good. Scanner communicates with every other module EXCEPT the pcm. It was shutting down on my way to my mechanics place but starting right back up. Flashing wait to start and water in fuel lights. Also would shut my overdrive off. Any ideas?
Old Jul 17, 2015 | 05:36 PM
tjc transport's Avatar
tjc transport
i ain't rite
is the scanner diesel compatible? not all scanners will read diesel truck codes.
Old Jul 17, 2015 | 06:18 PM
small_farms
Yes ive used this scanner in my truck before when my IDM went out and it read it.
Old Jul 18, 2015 | 12:53 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If I'm reading it right we have two problems. First the scanner cannot connect to the PCM, and the truck shuts off randomly, but other electric works, and it restarts. If that's not right please tell us more.
Just to rule it out, disconnect the fuel heater harness, replace the fuse, and leave harness disconnected.
For the shut down issue the first suspect is the CPS. Next would be intermittent power or bad grounds to the PCM. Check grounds high on driver side firewall and high on DS fender, near air filter. Power splice underneath air cleaner on wheel well liner seems to be a frequent issue recently. Switch the PCM and fan relays, maybe one is weak. I went thru all that to find a bad ignition switch was the culprit on mine.
Electrical problems can suck, but keep at it, we'll help you sort this out.
Old Jul 19, 2015 | 01:24 PM
small_farms
The truck did restart but now it's dead in the water after dying. It will turn over, but won't give me a wait to start light, and will not connect with a snap on scanner.
Old Jul 20, 2015 | 06:20 AM
Tugly's Avatar
Tugly
If your cigarette lighter is dead, you blew your OBDII connector power fuse.
Old Jul 20, 2015 | 12:59 PM
kbarbee95's Avatar
kbarbee95
My 00' does the same things cant connect to pcm, kept dying and restarting. Blew pcm diode, replaced and now no WTS light anymore. A fused are good. Subscribing.
02F350Dude
Mar 18, 2019 06:19 PM
LilF350
Aug 10, 2018 09:24 PM
11perry
Mar 6, 2017 07:34 PM
POWERSTROKE ARUBA
42
May 22, 2012 11:02 AM
78f3504x4
16
Oct 4, 2009 03:51 PM
