Troublesome 99 7.3 won't stay running. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-09-2018, 04:05 PM
LilF350
LilF350 is offline
LilF350 is starting off with a positive reputation.
Hey folks, first off I'm new here and come bearing mechanical knowledge minus the electrical part. I know a lot of you here have brilliant minds and may just have a clue for me. I've got a 99 7.3 CcLB f350 with 260k miles. Ive owned it now for about 7 years. Its also my first diesel. Current mods are WW2, 6637, Hydra, RiffRaff OCR and that's about it.
Okay, so heres my problem that I would like to see if any of you have experienced and successfully fixed without taking the truck to the stealership. After sourcing a few forums, I wasn't able to get a clear answer to a fix.
To shorten the post a bit, I've burnt my old PCM (dpc-402 XLE4) and went with an 01 dpc-422 PMT2. My PCM fuse and #30 fuse were both blown as well. Post new PCM install, I started my truck and it ran fairly crappy, like one bank was down. However it didn't smoke out the pipe. I turned off my truck and went back to restart it, and the only thing that happens is it fires up and immediately dies.
Here's what I've checked...
-Hpop res full.
-Oil is new.
-Fuel filter / inline good.
-CPS (new. grey)
-ICP and Pigtail (2 months old. Non MC)
-Fuel in the bowl.
-I have WTS, GP and FP all working.
-Batteries showing 12.10v
-Checked IPR tin Nut. Good.
-New UVCH harness / pigtail (ohmed out good)
-New beru germany MC GP's.
-New O'Reillys GP relay.
-New O'Reillys EOT sensor. (Old PCM said it was bad, when it worked)
I was able to pull codes and got the following; p1280, p0605, p0470. Also a code for an intake heater, which I never had (could this be a PCM difference issue that needs programming?)
I need this truck for commuting and use it as a daily driver and simply cannot afford a shop bill. Hope someone has an idea or can point me in the right direction of self diagnosis. Thank you folks, glad to be here.
Old 08-10-2018, 05:40 PM
mcnance865
mcnance865 is offline
mcnance865 is gaining momentum as a positive member of FTE.
Not to state the obvious, but did you upload new tunes to the Hydra using the new pcm code and not just leave the old ones there?
Also, you should ask a moderator to move this to the 7.3 section, you will get a lot more help. Or you could repost I guess.
Old 08-10-2018, 10:24 PM
LilF350
LilF350 is offline
Sorry guys didn't notice I wasn't in the 7.3 section, my fault. And mcnance, I did update the hydra and all its values. Today I went out to the truck and kept messing with wiring, sensors and all plugs. I finally got it to start, however it ran, it did not have the 'pep' it used to have. Took a while to raise RPMs with fully depressed throttle. After some more messing around, I have narrowed my problem down to the fuel pump not providing enough PSI. After the truck ran for a while, I performed a KOEO and found no codes. Thank you for.your time and reply. Hopefully this helps someone else out in the future.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
