Bad PCM and IDM?
Old Sep 21, 2009 | 06:06 PM
78f3504x4's Avatar
78f3504x4
Bad PCM and IDM?
My ongoing truck probs continue. I had all the CPS related issues, put in a new CPS, still the same probs. Scanned the truck, p1280 and p1298 came up. I brought it to a shop to check for shorts before I replaced anything. He said the PCM and IDM are shot. I found the guy in Florida with the reman $199 IDMs (beats $800-900 for a Ford one). Could the bad IDM be tripping the PCM?
Old Sep 21, 2009 | 06:56 PM
Hussler's Avatar
Hussler
PCM controls the IDM. Since you can get codes I would think, IMO, the PCM is working. I would be looking at the IDM.
Have you taken the IDM out of the truck and check for water damage. By that I mean shake it and listen for water intrusion. Can't tell you many times on here that is the issue. I have not looked at your past posts so maybe you have already done this.
Old Sep 21, 2009 | 07:48 PM
pjwoolw's Avatar
pjwoolw
The p1280: Injector control pressure sensor circuit low.
p1285: Injector driver module failure.
Just so you know.
Old Sep 21, 2009 | 10:32 PM
444dieselrod's Avatar
444dieselrod
i'd say its the IDM. if it was the PCM nothing would work, it prolly wouldnt run.
Diesel Rod
Old Sep 21, 2009 | 10:35 PM
pjwoolw's Avatar
pjwoolw
You could pull it out and see if its wet inside. There are other guys that fix them too. Maybe someone on this forum. Not sure though.
Old Sep 22, 2009 | 05:00 AM
78f3504x4's Avatar
78f3504x4
I'm gonna swap IDMs with my brother-in-laws truck ('97 PSD) before I buy one. Should I clear the codes before I start it after the swap? or just keep the batteries disconnected for a while?
Old Sep 22, 2009 | 07:44 AM
Action4478's Avatar
Action4478
Can you describe what the problems are ?...
Old Sep 22, 2009 | 04:19 PM
78f3504x4's Avatar
78f3504x4
Huge lack of power, engine cutting out for a second while driving, random stalling
Old Sep 22, 2009 | 05:03 PM
Copedawg's Avatar
Copedawg
Not good. I have noticed when the IDM goes it wont start. I have noticed when CPS goes it shuts off intermitently until it won't start at all. I haven't found what the PCM does when it goes. The IDM or CPS could go bad w/no power, I guess but I haven't seen it.
Old Sep 22, 2009 | 05:25 PM
Action4478's Avatar
Action4478
Have you got access to a scanner for some live data while driving ?..EOT sensor can cause that ,along with ICP sensor & IPR ...Need data to narrow it down
Old Sep 22, 2009 | 06:24 PM
78f3504x4's Avatar
78f3504x4
Wonderful. I've had it in two different shops, apparently no one knows how to properly diagnose the problems, so sick of flushing $$ down the toilet.
Old Sep 22, 2009 | 06:29 PM
78f3504x4's Avatar
78f3504x4
Not sure if it was scanned on the road, but I doubt it.
Old Sep 22, 2009 | 06:30 PM
78f3504x4's Avatar
78f3504x4
Will an IDM from a '97 work in my '95?
Old Sep 22, 2009 | 07:55 PM
yeldarb82's Avatar
yeldarb82
any idm from any year powerstroke will work in these trucks
Old Sep 23, 2009 | 07:04 PM
78f3504x4's Avatar
78f3504x4
So my wife followed me home from the shop today, about 10 miles. Truck stalled three times, and the motor cut out about 3 times at one point, and blew out a ton of black smoke at the tailpipe, but I floored it and it kept moving. Once I was on my street the check engine light went off, and it ran perfect. I swapped IDMs with my brother in laws truck ('97 PSD), and the same probs. Engine stalled, check engine light still on. I'm ready to give up.
