help plz
Old Apr 5, 2015 | 03:26 PM
kupiec20's Avatar
kupiec20
help plz
i have 3 of these trucks for atleast 15 years and i never had a issue getting an oil filter off.
any tricks? the thing wont budge.
i now have two rubber straps on it and still wont move. is there any reason why its stuck? any other tool i can use?
the filter is now starting to collaspe.
ty
Old Apr 5, 2015 | 04:02 PM
427 fordman's Avatar
427 fordman
Big a$$ water pump pliers.
Old Apr 5, 2015 | 07:52 PM
Bearhugger1933's Avatar
Bearhugger1933
Mine did the same way while I was having my oil changed,they couldn't get the filter to breake loose,a man came by and said to poke a hole in the bottom and let the oil drain out,they did this and then they were able to take it off,don't know how this worked but they were able to take it off then.
Old Apr 5, 2015 | 08:33 PM
95_Dually's Avatar
95_Dually
This is my tool of choice too for this task
Old Apr 6, 2015 | 01:24 AM
richdawg's Avatar
richdawg
I wouldn't use the rubber strap tools, to mulch flex. if you try a regular metal filter wrench and that don't do it try a 1/2 in. or so rod approx. a couple of feet long if necessary, sharpen one end and pound it through the filter near the bottom is best. It should give you plenty of leverage to get it loose, if you need more leverage add a length of pipe. This could save the expense of water pump pliers.
Old Apr 6, 2015 | 01:21 PM
darknight's Avatar
darknight
Screwdriver!
I've had the same exact situation.. And I used to work at a quick lube dealing with sticking filters all the time.
Take a large screwdriver, pop it through the side of the filter (going in horizontally), gently drive it through with a hammer until it pops out the other side. Then you have a nice large handle to give you lots of leverage. I've never had one not work this way. A little messier, but it gets the job done every time.
Old Apr 6, 2015 | 01:49 PM
madpogue's Avatar
madpogue
I've seen the screwdriver-through-the-side trick do a fine job of cutting the filter in two as well.
What are the strap wrenches doing? Are they slipping? Or just refusing to turn the filter? Depending on how its shaped, if it's just not turning, you might be able to slip a pipe over the end of the handle for more leverage. Otherwise, one of these silly things - Oil Filter Wrench with Locking Jaws - might just grab it.
Old Apr 6, 2015 | 07:28 PM
kupiec20's Avatar
kupiec20
how the hell did it get that tight!?
so i drove a rod through the filter and still wouldnt budge
then when i added filter remover with a bike chain (took both going at the same time to get it to move. wtf
i only hand tight my filters.
well ty.
Old Apr 6, 2015 | 07:46 PM
stainlessstroker95's Avatar
stainlessstroker95
Did you coat the o ring with oil before installation?
Old Apr 6, 2015 | 07:52 PM
CampSpringsJohn's Avatar
CampSpringsJohn
The vibration can make them tighten up over time. My "filter wrench" of choice for these is a huge pair of Channel-Lock pliers. The first one listed. #480
https://www.channellock.com/original-tongue-groove.aspx
I have to actually work it between the frame and body. I grip it just below the base. There was one time I couldn't break it loose and I ended up destroying the filter completely. I tore as much of the filter out of there that I could to where I could get to the base of the filter. I then used a hammer and chisel. Be careful if it comes down to this. You could go through the filter and damage the base thereby not allowing new filters seal like they should.
gasgrunt88
32
Jun 10, 2009 07:35 AM
air1jpg
2004 - 2008 F150
Aug 27, 2008 08:56 PM
150ford
28
Mar 10, 2005 11:01 PM
lee
Dec 1, 2003 01:33 PM
skeleton
Aug 20, 2002 10:37 PM
