Let me know if I am wrong.....
Old Jan 30, 2015 | 10:59 PM
Truckie256's Avatar
Truckie256
I had a customer today and he told me 6.7L contaminated DEF (diesel)repetitive problem (like every 3 months...he said), he said we couldn't fix it, another dealer told him they found a bad motor (cracked block?) was letting the diesel get into his DEF...???
I thought DEF went into exhaust system and only way to get diesel contamination was to take off cap and pour it in. the diesel in the engine has no way to get into the DEF tank and the only time DEF and diesel are anywhere near each other is being fed into exhaust from different source lines... Am I wrong??
Thanks
Old Jan 30, 2015 | 11:09 PM
Iowa Ford's Avatar
Iowa Ford
Truckie, I can't think of any way to possibly get diesel into the Def other than simly putting it in the Def tank by accident. Or vandalism.
You are correct, Def only gets injected in the Exhaust system, not in the motor.
Jus2shy's Avatar
Jus2shy
Wow, that makes no sense at all. Def is housed in a separate tank and is only routed to the exhaust. The only thing engine-related I can think of, doesn't ford route coolant to the DEF tank for defrosting purposes? But other than that, there's no interface between diesel and DEF except in the decomposition chamber where the DEF is injected into the exhaust stream.....
Or is this the case where DEF is getting into the diesel tank? If so, I'd also be a little lost on how that's happening aside from somebody pouring DEF straight into the diesel tank.
Either way, a cracked block/bad motor would not cause diesel to flow into the DEF tank.
Old Jan 30, 2015 | 11:13 PM
Truckie256's Avatar
Truckie256
he told me diesel in DEF.... I told him I didn't think it was physically possible...
he did tell me he asked his employee if he had put diesel in DEF by mistake and the employee said "NO" LOL....
the 3 month interval tells me the employee did it ... but maybe I am wrong.... maybe there is a way for it to happen...
Old Jan 30, 2015 | 11:22 PM
FishOnOne's Avatar
FishOnOne
Coolant isn't routed to the DEF tank. Sounds like a misfuel error on someone's part.
Old Jan 30, 2015 | 11:47 PM
Iowa Ford's Avatar
Iowa Ford
No there is not.
Old Jan 31, 2015 | 12:44 AM
92F350CC's Avatar
92F350CC
The employee did it.
Old Jan 31, 2015 | 01:36 AM
1954oldred's Avatar
1954oldred
N. Korea
Old Jan 31, 2015 | 06:34 AM
System's Avatar
System
Prolocutor
^^^ This or something along those lines....
Old Jan 31, 2015 | 08:17 AM
watchluvr4ever's Avatar
watchluvr4ever
Originally Posted by 1954oldred
N. Korea
Lol, too funny!
Old Feb 1, 2015 | 01:27 PM
kper05's Avatar
kper05
And repeats the same mistake apparently.
Old Feb 1, 2015 | 02:07 PM
miner999r's Avatar
miner999r
reminds of the old game "clue" - the employee did it as opposed to Colonel Mustard or Mrs. Plum!!
djed
Sep 25, 2016 12:02 AM
A/Ox4
23
Apr 23, 2012 06:32 PM
96ford4x4turbodiesel
Oct 18, 2005 12:47 PM
01stroker
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Oct 4, 2004 07:08 PM
fordman102
Jan 6, 2004 01:23 PM
