Ignition switch replacement on my '65 F-100
Old Jun 24, 2014 | 06:22 PM
peter sipp's Avatar
peter sipp
It has been sooooo long since I did it last time... I have forgotten how to do this. Would someone refresh my memory on this one, Thanks , cheers, Pete
Old Jun 24, 2014 | 07:00 PM
gangstakr's Avatar
gangstakr
Must have key and a paper clip or strong wire. Insert key, turn to ACC with paper clip depress pin continue turning key counter clock wise until key and cylinder come out. Once out you can turn bezel unscrewing it counter clock wise.
Do this slowly keeping pressure on the backside. once bezel is off slowly remove ignition watching out for the spring. Assembly is reversed.
Old Jun 24, 2014 | 07:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The spring is not replaceable, only furnished with the switch, and very rarely comes off.
Between the switch (11572) and the backside of the dash is a spacer (10A885).
The switch contains two pins, one larger than the other, ditto the bezel (11584).
When you push the spring loaded switch forward, the bezel does not unscrew, it twists off w/a 1/4" turn.
BEFORE messing with the switch, remove a battery cable!
Old Jun 24, 2014 | 07:36 PM
gangstakr's Avatar
gangstakr
Been awhile since I did one, Thanks N.D. for the correction. The spacer is what I meant not spring.
I've been doing more bump work than slick work. And working in the hot sun doing asphalt is not helping my memory one bit...... squirrel
Slim pickings in the PnP not able to keep my mind updated and refreshed.
Old Jun 25, 2014 | 01:20 AM
w5nra's Avatar
w5nra
What Bill said and that is 1/4 inch not 1/4 turn. Very much like a tail light bulb!
Old Jun 25, 2014 | 06:35 PM
peter sipp's Avatar
peter sipp
Replacing the ign sw. on my '65 F-100
Hi Bill, Thank you for the picture of the dash area. Thank you for the reminder about removing one of the batt. lead wires. I have the job to do. Now I am really ready. Cheers to you and all you love, Pete
Old Jun 29, 2014 | 06:28 PM
peter sipp's Avatar
peter sipp
Re: replacing the ign. sw. in my '65 F-100. I finished the job today. I appreciate your saying to remove a battery cable! I probably would not have. Now I have years to go before I need to put another in it. :-)
Old Jun 29, 2014 | 06:35 PM
peter sipp's Avatar
peter sipp
Hi Bill, I finished the job today. Thanks for suggesting I remove a battery cable. I probably wouldn't have!! Sure like knowing my ole faithful pal is just that again. Pete
pgr380
38
Feb 4, 2026 01:12 PM
deansbuild
Sep 22, 2012 04:15 AM
BPB
Jun 7, 2012 12:07 PM
bbearls
Jun 13, 2007 09:26 PM
fordtruckandtractor
Apr 17, 2005 11:30 AM
