Ignition Switch Replacement - '55 F100
Old Jun 13, 2007 | 10:12 AM
bbearls's Avatar
bbearls
I just got a replacement ignition switch from Mid-Fifty (so one key fits all) and am having trouble getting to the back of it. It's pretty crowded up under that dash. Do I have to remove the emergency brake handle and bracket to get to the switch?? I replaced both door locks and they work on the same key and it sure would be nice if I could start the truck with that key as well. Thanks/Bob.
Old Jun 13, 2007 | 03:08 PM
jimhackney's Avatar
jimhackney
You should remove the switch from the dash. Some of them you turn a quarter turn to get out, some have a bezel that snaps onto the switch barrel, others you screw off the bezel,
Old Jun 13, 2007 | 09:26 PM
jaye's Avatar
jaye
As mentioned above you can hold the switch from the back and turn the light switch bezel and it will turns off; you can also just replace the key ignition block by depressing the tab on top of the light switch (with the key in the ignition) then pull the key block out then do the same on the new one.
Jaye
BigWhite76
Jul 22, 2019 10:06 PM
ubereal2
Escape & Escape Hybrid
Sep 8, 2015 06:10 AM
broncoholic
Nov 8, 2013 07:04 AM
JoeSwing78
34
Aug 23, 2013 05:53 PM
