1994 Mazda B3000 Cold Air Intake
Old Feb 18, 2014 | 08:24 PM
7.3RP's Avatar
7.3RP
Question 1994 Mazda B3000 Cold Air Intake
I have a 1994 Mazda B3000 (Ford Ranger) and am going to install a 5.5 inch lift with 35 inch tires. I know this can be hard on the motor, should I consider installing a cold air intake ? Would this really even help enough to consider getting one, I don't want to be sluggish once I upgrade.Anybody have any experience with any of this, any suggestions??
Old Feb 19, 2014 | 07:00 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
You probably won't be able to notice any performance improvement over the stock air cleaner assembly. You will however see a huge loss of acceleration performance unless you swap to 4.10 or 4.56 axles to keep the RPM's up into the 3.0L's torque range. This issue is why Ford specified a 4.0L engine if you ordered 31x10.5 R15 tires (P265/75R15) as well as 3.73 axles.
Last edited by ranger pat; Feb 19, 2014 at 07:01 AM. Reason: I can't spell right the first time.
Old Feb 19, 2014 | 10:30 PM
KhanTyranitar's Avatar
KhanTyranitar
You gotta do gears or it s gonna be slow. No mater what you do to the intake and exhaust, you still have a poor flow, pushrod v6 motor with just 2 valves per cylinder.
If you switch to a different gear ratio, you will get better results.
Old Feb 20, 2014 | 10:25 AM
Conanski's Avatar
Conanski
Originally Posted by 7.3RP
I have a 1994 Mazda B3000 (Ford Ranger) and am going to install a 5.5 inch lift with 35 inch tires. I don't want to be sluggish
Well you're gonna be very disappointed. Is your truck auto or manual? I have two 3.0L Rangers here and the one with 4.10 gears is the only one that I would even consider putting larger tires on but even then nothing bigger than 32's. For 35s this truck should have 4.56 to 5.13 gears and especially of it has an auto trans.
Old Feb 20, 2014 | 07:31 PM
7.3RP's Avatar
7.3RP
I have the manual, looks like im going to be changing the gear ratios..
66shadow
Sep 26, 2012 10:16 PM
ShadowFury_FORD
2004 - 2008 F150
17
Jun 15, 2012 12:27 AM
caprisecca
Jun 14, 2012 02:09 AM
fuzzy jw
1997 - 2003 F150
39
Mar 2, 2010 04:13 PM
05RangerFX4
18
Nov 18, 2005 07:21 AM
