2000 7.3 LOOSING BOOST
Old Dec 26, 2013 | 01:53 PM
part time wheeler's Avatar
part time wheeler
I got a 2000 7.3 that cant seem to build any boost over 12-15 pounds. I just happen recently. I have pressure checked the cold side and it holds. I thought it could be the waste gate so I wired it shut. and it still wont build any above 12-15. I have a edge turner, gauges, 6.0 inter-cooler, boost fooler, turbo master, banks intake and 4" turbo back. I normally build around 20+ at WOT. Now it builds like normal but when it gets to 12-15 psi it blows it out. (loud shush). Could some one plese help me figure out this thing? I have it for sale and need to fix it before it goes.
thanks
Old Dec 26, 2013 | 03:26 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
Check (all) the boots. With the sound you describe, it must be leaking somewhere. Also poke around that 6.0 IC. The plastic end caps sometimes leak, or actually pop. Others will have more ideas.
Old Dec 26, 2013 | 03:29 PM
JWC 3's Avatar
JWC 3
I would also check all hoses and clamps . I see them blow or leak .
Old Dec 26, 2013 | 05:13 PM
part time wheeler
I just put the 6.0 ic on since I had one laying around. New boots and new ic. Thinking it would fix thr problem. It didn't. And it still does it with either one. Could the ebp flaper have anything to do with it? I unhooked it and no change but it seems like its a hot side problem.
Old Dec 26, 2013 | 06:52 PM
stinson 108-1
stinson 108-1
I'm surprised some of the more seasoned guys haven't chimed in yet, but try wiring open the ebpv. and see what happens. If its closing after the truck is up to temp, I wouldn't think it would make the 12-15lbs you are seeing. Anyway this reply will bump you up. Hang in there and you'll get help here, and welcome to the 99-03 forum. If you sell it, I hope its because you have your eye on another 7.3.
Old Dec 26, 2013 | 08:58 PM
Tailgate77478's Avatar
Tailgate77478
What do your uppipes look like? That's typically a big boost killer if they're leaking.
I recently had a boost leak that occurred after Mueckster and I rebuilt my turbo. I could HEAR the air escaping when accelerating, but couldn't find the leak. Turned out it was the fit of the spider to the turbo...it wasn't locked into place, and I could feel the air escaping from the clamp. Once I unclamped it and locked it into place, problem solved.
Old Dec 27, 2013 | 07:35 AM
Tugly's Avatar
Tugly
Stinky developed a leak at the intake plenum that would only show up at higher boost levels, that's another place to look. Have you done the boost leak detector with a spray bottle on everything boost related?
Old Dec 27, 2013 | 10:10 AM
part time wheeler
I have done a boost leak test already and covered everything. This morning the transmission just quite on me. Running about 45 mph and the nothing.... could the 2 problems be related to each other? the trains was replace about 30,000 miles ago and ever had a problem. I think it is more electrical???????
thanks
Chief Many Inches
20
May 6, 2017 09:49 PM
helloimjason
13
Apr 26, 2017 10:42 PM
deepseeman
May 31, 2016 09:49 AM
patnode22
Oct 31, 2014 04:49 PM
muddrag1
Oct 31, 2008 01:40 PM
