04 6.0 acting up again,installed rebuilt FICM Oct. 2012 having same symptoms as before, just this time No reading for FLP ...Scan G 2 rechecked values 4 times . Hot Or Cold Nothing ??? Any Ideas or is this mean no voltage? Thanks All. UGH!!!!!!
Try the numbers out of the tech folder, or scan gauge web, I think the ficm may have a bent pin eather plug or could be unit it self ,most of fte freinds use Ed at ficm repair, because he goes thru the whole unit and its done right (the first time ).What Issuies are you Haveing?
I found two different #s for TXD , tried both....still nothing. I bought this one from Ed, got a call into him now. When going up hills it wants to cough and has little power, same problem 15k ago. Installed unit from Ed and have been go to go ..until now, same symptoms. But before I could read FLP volts...not now???? Wondering..... Thanks.
I'm having the same problem. This is from AmDriven, he's the ScanGauge guru...
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
I have just installed my ScanGague and plugged in the many custom gauge features... but I cannot get my FLP to read anything...
Everything else works and I have no codes. Vehicle is running exceptional...
I DID however, recently have a BP FICM installed so maybe thats the rub???
Maybe Linear Logic has an answer??? I will try to call the customer service for them when I get a chance
Silly question. But have you checked that the plugs are in fact plugged all
the way into the FICM? I would also inspect the harness up to the FICM
for any chafing/pinching.
