No reading FLP
Old Apr 16, 2013 | 11:49 AM
rickkk's Avatar
rickkk
No reading FLP
04 6.0 acting up again,installed rebuilt FICM Oct. 2012 having same symptoms as before, just this time No reading for FLP ...Scan G 2 rechecked values 4 times . Hot Or Cold Nothing ??? Any Ideas or is this mean no voltage? Thanks All. UGH!!!!!!
Old Apr 16, 2013 | 12:01 PM
04badford's Avatar
04badford
Try the numbers out of the tech folder, or scan gauge web, I think the ficm may have a bent pin eather plug or could be unit it self ,most of fte freinds use Ed at ficm repair, because he goes thru the whole unit and its done right (the first time ).What Issuies are you Haveing?
Old Apr 16, 2013 | 12:15 PM
rickkk's Avatar
rickkk
FICM same issue
I found two different #s for TXD , tried both....still nothing. I bought this one from Ed, got a call into him now. When going up hills it wants to cough and has little power, same problem 15k ago. Installed unit from Ed and have been go to go ..until now, same symptoms. But before I could read FLP volts...not now???? Wondering..... Thanks.
Old Apr 16, 2013 | 01:16 PM
DawnPatrol's Avatar
DawnPatrol
I'm having the same problem. This is from AmDriven, he's the ScanGauge guru...
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
I have just installed my ScanGague and plugged in the many custom gauge features... but I cannot get my FLP to read anything...
Everything else works and I have no codes. Vehicle is running exceptional...
I DID however, recently have a BP FICM installed so maybe thats the rub???
Maybe Linear Logic has an answer??? I will try to call the customer service for them when I get a chance
***What is the OTHER code you have tried??*****
Old Apr 16, 2013 | 01:22 PM
rickkk's Avatar
rickkk
The 1st code that use to work inTXD was 0702209EF But tried CF ..but still no values!!??
Old Apr 16, 2013 | 01:26 PM
rickkk's Avatar
rickkk
Hey just got an E from Ed . He said to delete FLP & reinstall it. Rg
Old Apr 16, 2013 | 01:37 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I just went out and looked at mine.
Same as posted above. Works fine.
Not sure what is happening with this rash of FLP issues.
Hope you guys get it figured out.
Old Apr 16, 2013 | 01:45 PM
Yahiko's Avatar
Yahiko
FTE Remembers
Silly question. But have you checked that the plugs are in fact plugged all
the way into the FICM? I would also inspect the harness up to the FICM
for any chafing/pinching.
Sean
Old Apr 16, 2013 | 01:53 PM
BLADE35's Avatar
BLADE35
Theres a Fuse and relay that must work to get FLP & FICMMP
Do you get FICM MP??
Old Apr 16, 2013 | 01:55 PM
BLADE35's Avatar
BLADE35
IIRC if you did NOT have FLP the truck would not run so if runs bad it might be bad code and the drivability concern is something else
Old Apr 16, 2013 | 02:07 PM
BLADE35's Avatar
BLADE35
There have been a few isssues with 58volt FICM and gauges reading them correctly and NOT Limited to ScanGaugeII
However if you do have the 58v FICM SG should be able to tweek a code to read the higher voltage
Old Apr 16, 2013 | 06:56 PM
DawnPatrol's Avatar
DawnPatrol
Benny I kept my BP FICM at 48 volts... wanted to keep it OEM voltage
I am going to fire the engine up in a bit after deleting the original input and re-entering the same info in a new slot
Old Apr 16, 2013 | 08:50 PM
DawnPatrol's Avatar
DawnPatrol
Yep.... that was the ticket. I deleted the original input FLP and re-entered in a new slot and viola... it worked!
Also got my fuel level too... so now I have all I want put in
Old Apr 17, 2013 | 03:06 AM
Yahiko's Avatar
Yahiko
FTE Remembers
Good to hear you got it working.
Thanks for letting people know.
Sean
Old Apr 17, 2013 | 06:24 AM
T diesel's Avatar
T diesel
Good stuff!
gangstakr
13
Nov 5, 2017 07:31 AM
ford5.8
Oct 19, 2016 06:18 PM
turnrjr
Feb 11, 2009 11:31 AM
wiseguy50
Sep 18, 2005 11:11 AM
Lobo 2
Oct 1, 2003 01:06 PM
