Sponsored by: Real Truck
upgrading alternator 03 psd 6.0 110/140 question
Old Oct 25, 2011 | 09:35 AM
dapozer's Avatar
dapozer
need to replace the alternator on my 03, wanting to go with a 140 instead of the 110 and thinking going with the napa lifetime warranty one. However they do not list a 140 for a single alt application. do I just use the one for the dual set up? also do I need to look at increasing wire thickness on main wire?
Old Oct 25, 2011 | 10:17 AM
Wisebuck's Avatar
Wisebuck
The wire sould be the same for both, do you currently have 2 alts? If so then look at size difference between the two and mounting points. If they are the same then replace both with 140s if not then you have your answer.
Old Oct 25, 2011 | 10:30 AM
dapozer's Avatar
dapozer
single alternator set up
Old Oct 25, 2011 | 11:03 AM
Wisebuck's Avatar
Wisebuck
Changed mine earlier this year and opted for the 140 and she just bolted right up but I have the 5.4 gas in my 04 250 sd. Don't think you should have a prob with the 140 fitting.
frenchy107
Mar 15, 2011 02:07 PM
BIIman
Feb 14, 2007 12:38 AM
cterrysgd
Apr 20, 2005 08:50 AM
Ron Kelley
Aug 22, 2003 08:05 PM
beartracks
Electrical Systems/Wiring
Apr 8, 2002 08:59 PM
